Results 1 to 24 of 24
    Nov 2006
    canada
    Hi
    I'm slowly getting to know how to use yt-dlp, however I just cannot seem to set a permanent personal download file location.
    I've made an attempt to create configuration text file in the yt-dlp folder, but i cant get it to work.
    Any suggestions would be most welcome
    thanks
    Nov 2006
    canada
    Originally Posted by LZAA View Post
    '-P xxxx'
    Thanks, for some reason, previous advice I was given was to put -o (in the conf file)
    Nov 2006
    canada
    I am still having issues with this.
    I have a folder on My C drive with ffmpeg,ffprobe,ffplay and yt-dlp exe files in it.
    I created a text file called yt-dlp.conf with the following command
    -P "C:/Users/xxxxxx/Desktop/IDM\%(title)s.%(ext)s"
    The downloads still go to the default download location
  4. '-P "C:/Users/xxxxxx/Desktop/IDM"'
    Nov 2006
    canada
    I appreciate your response, but that didnt work
  6. In which directory does 'yt-dlp' save content?
    Nov 2006
    canada
    C:\Users\xxxxxx
  8. Write the command.
    Nov 2006
    canada
    Write the command.
  10. Write the command.
    Nov 2006
    canada
    Write the command.
    That is the command that I put in the conf. file
  12. Unfortunately, you do not understand the meaning of the word 'command'.
    Nov 2006
    canada
    I know that default download locations are set in the conf.file, I told you what was in my conf.file and I also tried your solution suggestion, which didnt work.
    Beyond that I have no idea what you are talking about, and clearly you arent going to tell me !
  14. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Place yt-dlp.exe and yt-dlp.conf both in the same empty folder to make sure nothing weird happens. You can add that folder later to system env vars.
    Make sure the yt-dlp.conf file is actually called "yt-dlp.conf" and not "yt-dlp.conf.txt" by checking that you can see the file extensions in the file explorer.
    My yt-dlp.conf is
    -P "C:\output"
    And I run:
    yt-dlp.exe "https://www.youtube.com/watch?v=jNQXAC9IVRw&vl=en"
    For me it works. Also make sure you're using the latest yt-dlp
    Nov 2006
    canada
    My yt-dlp.conf is
    -P "C:\output"
    And I run:
    yt-dlp.exe and yt-dlp.conf both in the same empty folder DONE
    Make sure the yt-dlp.conf file is actually called "yt-dlp.conf" DONE
    conf download location -P "C:/Users/xxxxxx/Desktop/IDM"
    download still ended up in C:\Users\xxxxxx
  16. Maybe use backslashes?
    Bypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2
  17. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Make sure you don't have a previous yt-dlp folder installation somewhere saved in your system env variables. Go to a random folder open cmd and type yt-dlp , it should yell that the command is unrecognized. Now go to that empty folder you made that has now the conf and exe, open cmd, and type my command. If it doesn't work with the wanted output, please show screenshot with that folder's structure and also the cmd with the command. You may edit out in paint any sensitive information.
  18. Member
    Nov 2006
    canada
    I have two versions of yt-dlp in my system env variables, but no idea what is what , or if they are both different
  19. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Delete everything yt-dlp related. Get a clean slate. The goal is to type yt-dlp in cmd in a random folder and it writes command unrecognized. My theory is that the yt-dlp versions are conflicting. You will restore yt-dlp back to system env, but after we make sure the output wanted works in a local folder.
    Nov 2006
    canada
    Thank you, that was an excellent suggestion,and it worked, perfectly.
  21. Originally Posted by mickmars View Post
    All you gotta do is add the URL to the end of that line. For me I put:
    yt-dlp -P "D:/Downloads" [url]
    And it downloaded it the file in my Downloads folder in my D drive.
    For me this is easier, I'm not savvy in cmd and I would have to add -P [path] each time but idk anything about a yt-dlp.conf file and whatnot. Why I made my download path simple
  22. Last edited by videoAI; 30th Oct 2024 at 12:19.
