I am looking for a codec for capturing video in windows. Something better than xvid or x264vfw with a GUI that can be configured from a capture software. Any suggestions?
Results 1 to 13 of 13
For VHS tape (or Video8, Hi8) capturing use YUV422 BT.601
FOURCC: ULY2Last edited by Sharc; 6th Nov 2023 at 14:00.
Try TechSmith Screen Capture Codec v.3.1, it is an compression codec which works great to use later to convert into any video format. When using for example MJPEG Compressor codec, an video file is 300-400MB with just 30-60 seconds recording and using TechSmith Screen Capture Codec v.3.1 with setting 'Better Compression' the video files can be sometime 10-20MB and after converting them theyre sometimes below 1MB with great quality.
This codec can be installed onto the computer and used by any screen recorder that have support for collecting installed codecs and use them.. Most dont! Try VSDC Free Screen Recorder v.1.3.2.531 or AutoScreenRecorder v.3.1.125. By installing for example Xvid MPEG-4 Codec onto your computer it can allso then be used with AutoScreenRecorder v.3.1.125... Both of them are Free and does not leave any watermarks!
Edit: If you would want to use MJPEG Compressor Codec it will give real smooth videos but many video converters fail to convert it and give bad image, allso to have huge source file will become an menace to store for an long time. TechSmith Screen Capture Codec v.3.1 is a lil bit better if you want to store the original source file and it allso have high successfull conversion rates with most video converters.Last edited by Swedaniel; 9th Nov 2023 at 09:24.
At the bottom of this site there is an "Affiliates: free-codecs.com". I think if you search for TechSmith Screen Capture Codec on that site it will list the version 8.2, if you click download it will allso list the 2.0, 3.0 and 3.1 version... Ill check for an download location for AutoScreenRecorder but i must go read the forum rules first, im not sure if it is ok to post alternate download links
Edit: The Codec is allso included with an Screen Recorder software, i dont remember which one. (After checking the date stamps on some installation files im pretty sure this codec come along with the AutoScreenRecorder v.3.1.125, and this codec, if installed, will allso come avalible from within VSDC Free Screen Recorder v.1.3.2.531)
The AutoScreenRecorder v.3.1.125 have theese file hashes, i think sometimes it is possible to search for the hashes to easier find an file (3,7MB EXE Installation File).
MD5
05b6b41332070354aab54b821762d732
SHA-1
49d1245a8a2447c87843b4228d9bdc343ec97933
SHA-256
5dfdaedddeb6ae73cc47c8e9ebe02dbfLast edited by Swedaniel; 10th Nov 2023 at 08:07.
Video codec profile
By Anonymous543 in forum Newbie / General discussionsReplies: 8Last Post: 16th Dec 2021, 14:08 -
What Is The Best Video Codec For Small File Size With Best Video Quality??
By DJboutit in forum Video ConversionReplies: 2Last Post: 14th Feb 2021, 07:58 -
Boilsoft Video Splitter doesn't recognize mp4 (video codec AVC)
By anderson20 in forum Newbie / General discussionsReplies: 0Last Post: 7th Jun 2020, 17:21 -
Laggy video after editing video on premiere and lagarith codec
By banane1 in forum Newbie / General discussionsReplies: 6Last Post: 17th Jan 2019, 11:09 -
Cant find the codec for this video
By supercain in forum Video ConversionReplies: 8Last Post: 25th Dec 2018, 22:51
