  1. https://mega.nz/folder/kDkxmJCI#VnK9HX_HeDC0-nzVHRcG1w
    .bik file play file with RADvideo
    http://www.radgametools.com/bnkdown.htm
    but theres no dialogue audio only play music track
    alan wake
  2. ffplay can't play the video, but it finds 16 audio streams
    Input #0, bink, from 'c:\Users\Selur\Desktop\cine_1200.bik':
      Duration: 00:00:30.87, start: 0.000000, bitrate: 6662 kb/s
      Stream #0:0[0x0]: Video: none (KB2j / 0x6A32424B), none, 1920x1080, 30 fps, 30 tbr, 30 tbn
      Stream #0:1[0x0]: Audio: binkaudio_dct, 48000 Hz, mono, fltp
      Stream #0:2[0x1]: Audio: binkaudio_dct, 48000 Hz, mono, fltp
      Stream #0:3[0x2]: Audio: binkaudio_dct, 48000 Hz, mono, fltp
      Stream #0:4[0x3]: Audio: binkaudio_dct, 48000 Hz, mono, fltp
      Stream #0:5[0x4]: Audio: binkaudio_dct, 48000 Hz, mono, fltp
      Stream #0:6[0x5]: Audio: binkaudio_dct, 48000 Hz, mono, fltp
      Stream #0:7[0x6]: Audio: binkaudio_dct, 48000 Hz, mono, fltp
      Stream #0:8[0x7]: Audio: binkaudio_dct, 48000 Hz, mono, fltp
      Stream #0:9[0x8]: Audio: binkaudio_dct, 48000 Hz, mono, fltp
      Stream #0:10[0x9]: Audio: binkaudio_dct, 48000 Hz, mono, fltp
      Stream #0:11[0xa]: Audio: binkaudio_dct, 48000 Hz, mono, fltp
      Stream #0:12[0xb]: Audio: binkaudio_dct, 48000 Hz, mono, fltp
      Stream #0:13[0xc]: Audio: binkaudio_dct, 48000 Hz, mono, fltp
      Stream #0:14[0xd]: Audio: binkaudio_dct, 48000 Hz, mono, fltp
      Stream #0:15[0xe]: Audio: binkaudio_dct, 48000 Hz, mono, fltp
      Stream #0:16[0xf]: Audio: binkaudio_dct, 48000 Hz, mono, fltp
    some contain dialogue audio, some don't,...
    => might be just a problem with you not listening to the right audio track
    (no clue about radtools)
  3. Originally Posted by Selur View Post
    this is newest bink version (2.5) from 2022 alan wake remastered
    should i upload the whole alan wake cutscene.bik folder?
    because when i try convert for example cine_1200.bik to avi or mp4
    RADvideo show if you want convert cine_1200.bik you must use cine_1300 cine_1400 as whole file in order to get avi or mp4 file
    mix them into one?
    this way we get
    dialogue track?
  4. plz there will never be another game like original alan wake
    alan wake 2 is out
    but it will never be like the same
    original alan wake just better than anything else
  5. Use 'Advanced play' in "RAD Video tools" and under 'Sound options' try 6 or higher until you find the language you want.
    => read http://www.radgametools.com/binkhlp2.htm and the linked pages,....
  6. Originally Posted by Selur View Post
    thanks you
    but
    how we get both background music and dialogue play as same time like the way they should be?
  7. Originally Posted by Selur View Post
    thanks you
    but
    how we get both background music track and dialogue track work on same time
    as right way they should be play?
  8. like I wrote read the help,...
    Audio settings:
    Play these sound track ids: This option lets you choose which audio tracks will play. You can play multiple tracks by separating them with semi-colons (like "0;1;2;3;4;5"). If you use XAudio, then the tracks will play in multichannel mode.
