Hi, I am not sure in which thread to post, therefore in the newbie section
I recorded a video with a screen capture software called Camstudio. Unfortunately the recording is corrupt and looks like this.
[Attachment 74667 - Click to enlarge]
I think the picture is self-explanatory. The video is split horizontally and vertically. The bottom should be at the top and vice versa. And the left should be right and vice versa.
It's an avi file.
Anyone an idea how to solve it? Is it perhaps a codec issue?
Thanks in advance.
regards,
kauf
Results 1 to 21 of 21
Thank you for your reply.
the attached video is just a sample that you can see/imagine how this video plays.
This is not the original avi-file.
I only can provide a short excerpt because of poor internet. And also have to convert it from avi to mp4 as even the excerpt has an avi-size of 3,7 gb. The original corrupt messed up file has a size of about 4 gb.
Thank you. -
Well a re-encoded copy is useless for determining whether there is something related to the decoding causing this problem.
Perhaps you should at least post a mediainfo report (in text view) of the file.
Whether or not it's possible to come up with a script that tracks those moving quadrants is another thing.
If they'd been still it would have been simple to crop and realign them -
Here's the mediainfo
General
Format : AVI
Format settings : BitmapInfoHeader
File size : 4.00 GiB
Duration : 1 h 8 min
Overall bit rate : 8 345 kb/s
Frame rate : 20.000 FPS
IsTruncated : Yes
Video
Format : RGB
Codec ID : 0x00000000
Codec ID/Info : Basic Windows bitmap format. 1, 4 and 8 bpp versions are palettised. 16, 24 and 32bpp contain raw RGB samples
Bit rate : 234 Mb/s
Width : 1 600 pixels
Height : 900 pixels
Display aspect ratio : 16:9
Color space : RGB
Bit depth : 8 bits
Bits/(Pixel*Frame) : 8.132
Stream size : 112 GiB -
I think I expressed myself incorrectly in post #3 in which I attached the mp4 excerpt. The sample clip there is extracted from the original avi-Video and just saved as mp4 file. Do you still need this clip as mkv or is the mp4 enough?
Indeed I can play it the old windows media player but as you can see in my first post it's like split and messed up. Other media players, even VLC and even after reindexing the avi header won't play this avi video.
Hi davexnet, it seems you did not see my #8 post https://forum.videohelp.com/threads/412196-repair-corrupt-messed-up-avi-file#post2711157 regarding a sample?
That file in post#3 was cut direct from the source without re-encoding?
IT does not agree with the file details you posted in post#6 -
I am not sure if it was re-encoded. I will try to send a new short sample without re-encoding.
Thanks meanwhile -
I see this, but I don't know what's wrong. DId you try saving to avi instead?
Also you can use ffmpeg to save a clip:Code:[HandleAction] 21:00:46-850 ************ SAVE_VIDEO ************** [dxvaRender::draw] 21:00:47-801 D3D : Draw! [dxvaRender::refresh] 21:00:47-801 Refresh** [admSaver::admSaver] 21:00:49-360 [Save] Encoder index=0 [admSaver::save] 21:00:49-360 Audio starting time 00:00:00,000 [admSaver::save] 21:00:49-360 [A_Save] Saving.. [ADM_Composer::checkCutsAreOnIntra] 21:00:49-360 Checking cuts start on keyframe.. [muxerMkv::muxerMkv] 21:00:49-360 Creating Matroska muxer. [admSaver::setupVideo] 21:00:49-360 Simple copy mode engaged [ADM_videoStreamCopy::ADM_videoStreamCopy] 21:00:49-361 Creating copy video stream, start time: 00:00:00,000 [ADM_videoStreamCopy::ADM_videoStreamCopy] 21:00:49-361 End time: 00:00:34,750 [ADM_Composer::getTimeBase] 21:00:49-361 Ref video 0 is frame-encoded, copy mode: 1 [ADM_Composer::getTimeBase] 21:00:49-361 Timebase set to 1 / 10 [ADM_Composer::getFrameNumFromPtsOrBefore] 21:00:49-361 Best candidate for time 00:35:43,500 in reference is frame 14344 [ADM_videoStreamCopy::ADM_videoStreamCopy] 21:00:49-361 PTS/DTS delta=0 us [ADM_videoStreamCopy::ADM_videoStreamCopy] 21:00:49-362 Fixating start time by 0 [ADM_videoStreamCopy::ADM_videoStreamCopy] 21:00:49-362 Starting DTS=0, PTS=0 ms [admSaver::setupAudio] 21:00:49-362 Setting up 0 audio track(s) [FF] Muxer opened [muxerFFmpeg::initVideo] Initial audio delay: 0 ms [FF] Using 0 bytes for video extradata [FF] Unknown video codec [muxerMkv::open] 21:00:49-362 [Matroska] Failed to init video. [dxvaRender::draw] 21:00:49-595 D3D : Draw! [dxvaRender::refresh] 21:00:49-595 Refresh** [muxerMkv::~muxerMkv] 21:02:47-561 Destroying Matroska muxer.
This will save 30 seconds starting at 5 seconds offsetCode:ffmpeg.exe -i "c:\path\source.avi" -ss 00:00:05 -t 30 -c:v copy -an clip.avi
[HELP] Corrupt MPG file
By Knalpiep in forum Newbie / General discussionsReplies: 2Last Post: 27th Jan 2023, 04:36 -
How to repair AVI file - dashcam footage for accident
By kp278 in forum Newbie / General discussionsReplies: 13Last Post: 7th Dec 2022, 02:17 -
Can anyone help with a corrupt. MOV file?
By Nakken89 in forum Software PlayingReplies: 20Last Post: 30th Jul 2021, 18:25 -
Repair avi file?
By David Banner in forum EditingReplies: 19Last Post: 20th Nov 2020, 14:03 -
Empty or corrupt VOB file?
By Filos in forum Newbie / General discussionsReplies: 8Last Post: 17th Apr 2020, 18:05
