I just downloaded Spiderman SVCD 2 Centropy version (1 and 3 still downloading) and even though iti is .mpg it doesn't play in Media Player or Quicktime? Is there a file I need to download for it to play? Do i need to convert? What program will this play in? Is it corrupt?
Chris
You need an SVCD player which decodes mpeg-2. Some software DVD players will play it. Also Elecard will play it. There is also a mpeg-2 codec that you can install and it will probably play in WMP.
Darryl -
Get Power DVD it will play anything. If u want u can e-mail me and i'll tell u where u can get it.
brad31365@yahoo.com -
Unless its an image file. I've seen VCD .bin and .cue image file for movies. If it is IsoBuster may work.
Just download the free MPEG2 codec. Your machine is just missing it, thats all.
Lagarith won't play in MPC or WMP
By mst in forum Newbie / General discussionsReplies: 1Last Post: 29th Jan 2012, 18:29 -
WMP 10 won't play avi with subtitle file.
By zlmdlo in forum Software PlayingReplies: 1Last Post: 14th Dec 2009, 04:22 -
DVD to something Quicktime and WMP can play
By Hardway in forum DVD RippingReplies: 2Last Post: 13th Aug 2008, 14:22 -
WMP/MPC won't play any mpeg video
By hhhgamewmx7 in forum Software PlayingReplies: 3Last Post: 20th Feb 2008, 10:36 -
Files that won't play properly in WMP or after conversion
By Trapper Dave in forum Video ConversionReplies: 1Last Post: 3rd Jun 2007, 13:26
