Results 1 to 14 of 14
  1. Banned
    Oct 2023
    Los Angeles
    Whenever I convert a .bik file by using RAD Games Tools, the audio was a little off, like it was slightly garbled. What should I do to fix the audio to make it sound like normal?
    P.S. Can someone answer my last question too? https://forum.videohelp.com/threads/412138-bik-and-thp-Help
    Mar 2008
    Can you provide a sample source file?
  3. Banned
    Oct 2023
    Los Angeles
    How? By using MediaInfo?
    Mar 2008
    You can do that too, but I'm talking about uploading one of the files so we can look at it.
    Come on man, how do you expect any help? You gave zero useful info
  5. Banned
    Oct 2023
    Los Angeles
    I played both the .bik and the converted files on KMPlayer and they both sounded off, but when I played the former on RAD Video Tools and it sounded normal. It turns out the video player was the problem.
    Still, what video players other than RAD Games Tools can play .bik video files with the normal sounded audio? How do I get converted files to sound the same? And how do I remux .bik and .thp files to other formats?
    Here is the MediaInfo for the converted files (sorry I don't know how to place videos here):
    For MP4:
    General
    Complete name :clockwerk_intro.mp4
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42 (mp41/isom)
    File size : 16.0 MiB
    Duration : 36 s 386 ms
    Overall bit rate : 3 678 kb/s
    Encoded date : UTC 2023-11-02 17:27:02
    Tagged date : UTC 2023-11-02 17:27:02
    Video
    Format : AVC
    Format profile : Baseline@L5.1
    Format settings, CABAC : No
    Format settings, RefFrames : 2 frames
    Format settings, GOP : M=1, N=60
    Codec ID : avc1
    Duration : 36 s 367 ms
    Bit rate : 3 485 kb/s
    Width : 640 pixels
    Height : 480 pixels
    Display aspect ratio : 4:3
    Frame rate mode : Constant
    Frame rate : 30.000 FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.378
    Stream size : 15.1 MiB (95%)
    mdhd_Duration : 36367
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Bit rate mode : Constant
    Bit rate : 192 kb/s
    Channel(s) : 2 channels
    Sampling rate : 44.1 kHz
    Frame rate : 43.066 FPS (1024 SPF)
    Compression mode : Lossy
    Stream size : 853 KiB (5%)
    mdhd_Duration : 36386
    For AVI:
    General
    Complete name : clockwerk_intro.avi
    Format : AVI
    File size : 965 MiB
    Overall bit rate : 223 Mb/s
    Video
    Format : RGB
    Codec ID : 0x00000000
    Codec ID/Info : Basic Windows bitmap format. 1, 4 and 8 bpp versions are palettised. 16, 24 and 32bpp contain raw RGB samples
    Bit rate : 221 Mb/s
    Width : 640 pixels
    Height : 480 pixels
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 24.000
    Stream size : 959 MiB (99%)
    Audio
    Format : PCM
    Format settings, Endianness : Little
    Format settings, Sign : Signed
    Codec ID : 1
    Duration : 36 s 365 ms
    Bit rate : 1 411.2 kb/s
    Bit depth : 16 bits
    Stream size : 6.12 MiB (1%)
    Alignment : Aligned on interleaves
    Interleave, duration : 983 ms (29.49 video frames)
    Mar 2008
    See here:
  7. Banned
    Oct 2023
    Los Angeles
    See here:
    Here you go. The bik was invalid and the avi was too large.
  8. Originally Posted by Jay123210599 View Post
    See here:
    Pack the bik into a zip and post the zip
    Mar 2008
    See here:
    BIK is invalid because the site does not recognize the file extension. All you have to do is compress it to zip or 7z and
    upload that. I'd like to take a look at the source
    The file you posted seems perfectly fine. Is this suppsoed to illustrate something?
  10. Banned
    Oct 2023
    Los Angeles
    See here:
    Did you play the video? What video player did you use? By the here's the other two files. https://files.videohelp.com/u/307977/videos.7z
  11. Originally Posted by Jay123210599 View Post
    Both play fine with VLC Player.
    Here a properly cropped recoding with clever FFmpeg-GUI.
    btw
    your bik has 8 audiostreams, all the same.
  12. Banned
    Oct 2023
    Los Angeles
    btw
    So the problem was the video player that used to play the videos. Thanks!
    By the way, do you know how to .bik and .thp files into other formats like mkv? I tried FFmpeg but that didn't work at all for both types of files. Any tools or software that can help?
  13. Bink video and audio goes only into the bik container.
    ffmpeg isn't able to mux them. But ffmpeg can decode both, so you can recode video and audio with ffmpeg into any other format supported.
    (g.e. my sample from post #11).
  14. Banned
    Oct 2023
    Los Angeles
    What if I convert .bik and .thp files into lossless codecs like FFV1, FLAC, WAV, and H.264/H.265 lossless? Will that be the same as remuxing videos without reencoding them?
