  1. Trying to capture video from 20 DV tapes to my Mac using FFMPEG pro. Consistently get the following error (below), but the capture seems to be fine. I am an absolute novice at this, and don't wan't to continue if I am doing something wrong. Using a CANON VIXIA HV40 and 2017 15inch MBP running macOS Ventura 13.6 .
    Any thoughts?
    The terminal command used is : ffmpeg -f avfoundation -capture_raw_data true -i "VIXIA HV40" -c copy -map 0 -f rawvideo ArchiveDV18.dv
    This leads to the following error message:
    ffmpeg version 6.0 Copyright (c) 2000-2023 the FFmpeg developers
    **built with Apple clang version 14.0.3 (clang-1403.0.22.14.1)
    **configuration: --prefix=/usr/local/Cellar/ffmpeg/6.0_1 --enable-shared --enable-pthreads --enable-version3 --cc=clang --host-cflags= --host-ldflags= --enable-ffplay --enable-gnutls --enable-gpl --enable-libaom --enable-libaribb24 --enable-libbluray --enable-libdav1d --enable-libjxl --enable-libmp3lame --enable-libopus --enable-librav1e --enable-librist --enable-librubberband --enable-libsnappy --enable-libsrt --enable-libsvtav1 --enable-libtesseract --enable-libtheora --enable-libvidstab --enable-libvmaf --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libxvid --enable-lzma --enable-libfontconfig --enable-libfreetype --enable-frei0r --enable-libass --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libspeex --enable-libsoxr --enable-libzmq --enable-libzimg --disable-libjack --disable-indev=jack --enable-videotoolbox --enable-audiotoolbox
    **libavutil** * *58.**2.100 / 58.**2.100
    **libavcodec* * *60.**3.100 / 60.**3.100
    **libavformat** *60.**3.100 / 60.**3.100
    **libavdevice** *60.**1.100 / 60.**1.100
    **libavfilter* * *9.**3.100 /**9.**3.100
    **libswscale** * *7.**1.100 /**7.**1.100
    **libswresample* *4. 10.100 /**4. 10.100
    **libpostproc** *57.**1.100 / 57.**1.100
    [avfoundation @ 0x7fe5ae0049c0]*Selected framerate (29.970030) is not supported by the device.
    [avfoundation @ 0x7fe5ae0049c0]*Falling back to default.
    [avfoundation @ 0x7fe5ae0049c0]*Selected pixel format (yuv420p) is not supported by the input device.
    [avfoundation @ 0x7fe5ae0049c0]*Supported pixel formats:
    [avfoundation @ 0x7fe5ae0049c0]***uyvy422
    [avfoundation @ 0x7fe5ae0049c0]***yuyv422
    [avfoundation @ 0x7fe5ae0049c0]***nv12
    [avfoundation @ 0x7fe5ae0049c0]***0rgb
    [avfoundation @ 0x7fe5ae0049c0]***bgr0
    [avfoundation @ 0x7fe5ae0049c0]*Overriding selected pixel format to use uyvy422 instead.
    Feb 2006
    Any thoughts?
    for the selected framerate error see here - https://stackoverflow.com/questions/38498599/webcam-with-ffmpeg-on-mac-selected-framer...upported-by-th
    and for the error "Selected pixel format (yuv420p) is not supported by the input device"
    try adding -pixel_format nv12 to your ffmpeg command.
