Results 1 to 12 of 12
  1. which one is the better motion to save my divx files to convert to vcd later ?
    fast or low?
    i know its a stupid question but i really wants to know.
    thanks
  2. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    high or fast
  3. yes is it...
    i dowloaded some videos in divx but the quality isnt too good.
    ild like to know which is the best motion?
    if u can suggest some filters to aplicate over movies to increase the quality of my vcds ill apreciate.
  4. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Sorry, no clue about the filters. I've never used any in my VCD creations.
    Jun 2001
    England
    DivX isn't a very good archive format.
    If you have bad quality DivX videos then no amount of filters will get the detail back. All you can hope to do is clean it up a bit.
  6. thanks...
    but the quality isnt totally bad just some blockiness in some parts of that movies...
    i just want to clean the original files...
    if i try something like increase bitrate or something like this ..
    what do u suggest....?
    Jun 2001
    England
    You might be able to remove some of the blockiness with a VirtualDub filter called "Smart Smoother". Be warned though that the video will look more blurred as a result.
    I suggest that you first try encoding a sample of it it to a VCD (without using any filters or changing settings). If you are not happy with the results then start fiddling.
  8. smart smoother? where to get a hold of that?
  9. smart smoother? where to get a hold of that?
    I got a dvd ripped movie from edonkey and some parts i could see very minor blockiness in the background..
    should i attempt to use smart smoother?
  10. great idea...!
    i have the same movies in mpg1 ....
    i ll test it...
    hey playndirty 101
    try here====>http://sauron.mordor.net/dgraft/smooth.html
  11. thanks willy, let me know how it turned out for u
  12. im sorry ..but i cant test it yet
