Works fine however when Picture Search is requested, the tape loses tension momentarily and the machine scratches the tape causing permanent damage.
I'd like to find a schematic or service manual.
My novice guess is that the electronic back tension needs marginally increased.
	Check & clean the mode switch, just a guess *** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE
	You may want to check both take up and supply spindles' brake pads, The easiest way to check them is with the lid off, insert at least a 2hr cassette, fast forward until it picks up speed and hit stop, this checks the supply spindle brake, then rewind until it picks up speed and hit stop, this checks the take up spindle brake, if the reel/spindle keeps spinning after stop you got worn out brake pads.
 Don't mess with tape tension, increasing it will only make things worse.
  Toshiba VCR's-any good than JVC HR-737MS?By Idan1822 in forum MediaReplies: 2Last Post: 18th May 2023, 11:50
  multiAVCHD 4.1.771 is crashing when I do just about anythingBy NfaToys in forum Authoring (Blu-ray)Replies: 4Last Post: 2nd Sep 2021, 16:26
  Where to professionally repair/refurbish a vintage VCR in the year 2020?By echo1434 in forum MediaReplies: 23Last Post: 13th Jul 2021, 22:17
  Capturing SVHS using a standard VHS VCR - Is it possible?By DJ Kris in forum Capturing and VCRReplies: 15Last Post: 4th Jul 2020, 13:00
  Horizontal jitter on Panasonic PV-VS4820 SVHS VCRBy ChunkDaMan in forum Newbie / General discussionsReplies: 0Last Post: 22nd Jul 2019, 16:39
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
