  1. Hello
    I recently bought the title card for little money, I work on Linux, I use Panasonic HS960 + Pioneer dvr 560. Everything works fine. Most of the time I tested the component connection but I also have the option to check s-video with ffmpeg software. Does anyone use a similar devices and have any advice or tips?
    Greetings
  2. I'm currently using the following code to capture via s-video from pioneer recorder:
    ffmpeg \
    -cpucount 16 \
    -hide_banner \
    -err_detect +crccheck+bitstream+buffer+compliant+aggressive \
    -format_code pal -f decklink -i 'Intensity Pro' \
    -aspect 4:3 \
    -vcodec ffv1 -level 3 -threads 16 -coder 1 -context 1 -g 1 -slices 30 -slicecrc 1 \
    -pix_fmt yuv420p \
    -colorspace bt470bg \
    -color_primaries bt470bg \
    -acodec pcm_s16le \
    -vf "crop=in_w-2*8" \
    test_capture-$(date +%F-%I-%M-%N).mkv
    [decklink @ 0x563f2af1da00] Found Decklink mode 720 x 576 with rate 25.00(i)
    Guessed Channel Layout for Input Stream #0.0 : stereo
    Input #0, decklink, from 'Intensity Pro':
      Duration: N/A, start: 0.000000, bitrate: 167424 kb/s
      Stream #0:0: Audio: pcm_s16le, 48000 Hz, 2 channels, s16, 1536 kb/s
      Stream #0:1: Video: rawvideo (UYVY / 0x59565955), uyvy422(top first), 720x576, 165888 kb/s, 25 fps, 25 tbr, 1000k tbn
    Stream mapping:
      Stream #0:1 -> #0:0 (rawvideo (native) -> ffv1 (native))
      Stream #0:0 -> #0:1 (pcm_s16le (native) -> pcm_s16le (native))
    Press [q] to stop, [?] for help
    Output #0, matroska, to 'test_capture-2023-10-29-02-07-413691944.mkv':
      Metadata:
        encoder         : Lavf60.3.100
      Stream #0:0: Video: ffv1 (FFV1 / 0x31564646), yuv420p(tv, bt470bg/bt470bg/unknown, top coded first (swapped)), 704x576 [SAR 12:11 DAR 4:3], q=2-31, 200 kb/s, 25 fps, 1k tbn
        Metadata:
          encoder         : Lavc60.3.100 ffv1
      Stream #0:1: Audio: pcm_s16le ([1][0][0][0] / 0x0001), 48000 Hz, stereo, s16, 1536 kb/s
        Metadata:
          encoder         : Lavc60.3.100 pcm_s16le
    frame=  330 fps= 25 q=-0.0 size=   76544kB time=00:00:13.20 bitrate=47503.7kbits/s speed=1.02x
    [q] command received. Exiting.
    Video
    Format                                   : FFV1
    Format version                           : Version 3.4
    Format settings, GOP                     : N=1
    Codec ID                                 : V_MS/VFW/FOURCC / FFV1
    Duration                                 : 13 s 680 ms
    Bit rate mode                            : Variable
    Bit rate                                 : 45.3 Mb/s
    Width                                    : 704 pixels
    Height                                   : 576 pixels
    Display aspect ratio                     : 4:3
    Frame rate mode                          : Constant
    Frame rate                               : 25.000 FPS
    Standard                                 : PAL
    Scan type                                : Interlaced
    Scan type, store method                  : Interleaved fields
    Scan order                               : Top Field First
    Compression mode                         : Lossless
    Bits/(Pixel*Frame)                       : 4.471
    Stream size                              : 73.9 MiB (95%)
    Writing library                          : Lavc60.3.100 ffv1
    Default                                  : No
    Forced                                   : No
    Color range                              : Limited
    Color primaries                          : BT.601 PAL
    Matrix coefficients                      : BT.470 System B/G
    coder_type                               : Range Coder
    MaxSlicesCount                           : 30
    ErrorDetectionType                       : Per slice
    I have two question should I use"
    -pix_fmt yuv420p
    -vf "crop=in_w-2*8"
    The last it is to crop size to 704.
    Thank you for your advice.
