[Attachment 74544 - Click to enlarge]Hi all
I have captured serval VHS tapes and noticed of 5:4 display aspect ratio 720x576 PAL.
Why am I getting 5:4 on mediainfo?
On VLC's media info I do not see the aspect ratio.
How do I know if my capture file is ok?
Results 1 to 9 of 9
MediaInfo just reports it as 720/576 = 1.25 = 5/4.
For playing the file you have to force the player to play it as 4:3
For encoding you should either
- specify the DAR (Display Asect Ratio) as 4:3 or specify the SAR(Sampling Aspect Ratio) as 12:11
- or resize it to square pixels -
Your capture does not have an aspect ratio flag yet, Mediainfo judges the aspect ratio based on the resolution and assuming pixels are square, In reality digital SD video from analog sources does not have square pixel architecture, Pixels are rectangular.
Absolutely normal. 720*576 is the standard resolution for a PAL capture. Since your capture file does not have a DAR (Display Aspect Ratio) flag, mediainfo simply applies width*height which equals 5*4.
I guess you will eventually convert your file to a more manageable size with a codec that has a DAR. Or simply force it to 4:3 in a player such as VLC -
Yes, it is normal. Unknown because the capture file is not flagged.
It has to be stretched to 4:3 upon playback. Now you see a slightly squashed picture. -
Your capture is fine.
If you encode it (to obtain a smaller file), set the 4:3 or 16:9 flag as DAR. -
Pixel Aspect Ratio
By biferi in forum Newbie / General discussionsReplies: 54Last Post: 3rd Feb 2024, 05:34 -
JPG Aspect Ratio
By Anakin in forum EditingReplies: 5Last Post: 23rd Dec 2022, 06:05 -
Graphic Aspect Ratio
By biferi in forum Newbie / General discussionsReplies: 1Last Post: 8th Jun 2021, 12:51 -
Aspect Ratio
By wks in forum Newbie / General discussionsReplies: 10Last Post: 1st May 2020, 13:57 -
Help with pixel aspect ratio
By blue24 in forum Video ConversionReplies: 12Last Post: 28th Dec 2018, 18:36
