I have a VHS capture that I used Lagarith lossless compression set at YUY2 mode in Amarec. I shortened the video using the same codec in virtualdub2 and set the compression and mode to the same but with pixel format set to YUV422, which isn't an option in Amarec, expecting mediainfo to display the same parameters, but they are slightly different. Shouldn't the bitrate be the same?
source:
Video
Format : Lagarith
Codec ID : LAGS
Duration : 1 h 4 min
Bit rate : 47.7 Mb/s
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 3:2
Frame rate : 29.970 (30000/1001) FPS
Standard : NTSC
Bits/(Pixel*Frame) : 4.603
Stream size : 21.5 GiB (93%)
trimmed video:
Video
Format : Lagarith
Codec ID : LAGS
Duration : 46 min 49 s
Bit rate : 50.4 Mb/s
Width : 720 pixels
Height : 480 pixels
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:2
Bit depth : 8 bits
Bits/(Pixel*Frame) : 4.868
Stream size : 16.5 GiB (97%)
The codec is lossless not uncompressed, so for any size produced you have to take into account the complexity
of the video
Syncying movie sound when one video is slightly faster
By adrian44 in forum EditingReplies: 6Last Post: 27th Aug 2023, 05:17 -
Slightly Jerky Video-Can It be Smoothed?
By Alwyn in forum RestorationReplies: 17Last Post: 6th Jun 2023, 00:55 -
[multiAVCHD] I can't change the AC3 bitrate setting.
By kerott in forum Authoring (Blu-ray)Replies: 0Last Post: 21st Sep 2020, 00:45 -
TsMuxer shortening video portion of M2TS file
By dobyblue in forum Video ConversionReplies: 3Last Post: 5th May 2020, 06:20 -
Re-encoding audio and video to lower bitrate and change channel to mono
By DennisO in forum AudioReplies: 7Last Post: 26th Dec 2018, 14:25
