is there any way to make sure you are getting a good, high number for fps before you download a movie? 29.97 is supposed to be normal but the last one I got was only 12.5, which is about less than half that.
If you are using a p2p to download from just make sure that the bandwidth rate is high i usually try to find someone with at least 500 plus if i can find someone with a 1,000 plus i can pull on a average 190kb.
Yes there is a way I do it all the time. I use kazaa so I will tell you how to do it through that. Okay the .dat file kazaa makes while it downloads, copy that to another folder( it may be large) then open it with vitual dub. It will tell you it had to rebuild the index file, this is normal. Then hit F5 it will start to play the video and will show you the video render rate, this is the frame rate. I had that prob to, "The New Guy" is only 12.5 FPS! I wanted it so I put up with it.
how do you make a dat file while its downloading cause i can only make one when its completed?
It makes the dat files when it downloads to your computer automatically.
This is proboly a ice cream induced thought so i can not take no control for the above statment. :P
Is the FPS of a MiniDV camera higher than the FPS of DVD video?
By granturissimus in forum Newbie / General discussionsReplies: 8Last Post: 9th Jan 2011, 06:40 -
mixing 1280 x 720 29,97 fps and 1440 x 1080 25 fps in final cut
By perik in forum EditingReplies: 6Last Post: 17th Nov 2010, 23:42 -
how to change fps in mp4 without reencode (maybe ps3 cannot handle 24 fps)?
By redout66 in forum Newbie / General discussionsReplies: 1Last Post: 14th Sep 2010, 05:53 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 16:23 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 20:17
