I work with video in a school and I found a Elinchrom BX 500 Ri stored away. I know this equipment is made for photography, but is it possible to use it for video? And if so is it possible to change the tone of the light? It is yellow and I need white light.
Thank You.
Some Elinchrom flash units, like the BX 500 Ri, have a continuous light mode. In this mode, they provide a constant light source that can be used for video. You'll need to check the manual for your specific model to see if it has this feature.
The color temperature of most flash units is typically around 5500K, which is close to daylight. If your unit can be used in continuous light mode, it will produce a white light that should work well for video. However, if it produces a color cast that is too warm i.e. yellowish, you may need to use color correction filters to adjust the color temperature of your preference. In your case, you'd want to use a cooling blue gel to correct the yellowish tint and make the light more neutral, closer to 5500K.
Lighting when doing an interview or portrait
By Kenny202 in forum Newbie / General discussionsReplies: 1Last Post: 30th Sep 2023, 09:55 -
Lighting my small green screen
By JJisawesome25698 in forum Newbie / General discussionsReplies: 2Last Post: 6th Dec 2020, 11:55 -
Tips to improve this lighting?
By philraymond in forum Newbie / General discussionsReplies: 0Last Post: 8th Oct 2020, 17:23 -
Question regarding cropping in OBS studio
By rocknrolla115 in forum ComputerReplies: 0Last Post: 21st Dec 2019, 16:24 -
Video lighting help
By Danitwelve91 in forum EditingReplies: 4Last Post: 9th Jul 2019, 01:31
