  1. Hi, I know it should be pretty simple, but does anyone how to install codecs (eg Huffyuv) into Amarec?. I tried copying the file over the fiolder but it doesn't do anything; I tried this for VDun by dropping the file and it worked for that. I am currently using Lagarith but the file size is quite large. Will other codecs reduce the file?
    Mar 2008
    Codecs are available in AmarecTV once they're installed in Windows.
    Another option is UT codec; capture in 4:2:2 chroma
    https://www.videohelp.com/software/Ut-Video-Codec-Suite
  3. Originally Posted by davexnet View Post
    Thanks for that. I just installed the download file and it installed it automatically into Amarec, though there are 6 different UT codecs in the list.
    Also just to add, some comments for this codec are suggesting it's full of malware.
    Mar 2008
    It's been developed for years and it's still supported/updated and Videohelp.com has it in their software section.
    Any malware reported is a false positive
  5. Originally Posted by davexnet View Post
    No worries thanks, thought so
    Jul 2023
    Italy
    I downloaded huffy in windows, right click and install the inf file, something flashes on screen for 0.001 seconds.
    Then I restart AmarecTV and refresh the list, and it's not there.
    I then tried UT, however it installed 20 codecs, and no idea which one to use...
    Can you help?
    May 2005
    PAL User
    @wcndave2, yes, unfortunately getting HUFF onto your machine isn't easy. Have a read of this:
    https://github.com/hofmand/video-codec-installers
    That should get you going.
    Jul 2023
    Italy
    32 bit version msi was the option that worked, thanks!
