its thare any way to get the pssh and kid ?
https://svc40.main.vr.t-online.de/LCID3221228215.originalserver.prod.sngtv.t-online.de...3221228215.mpd
kind regarts
Results 1 to 11 of 11
try this
Code:kid 322D10DD-B94C-12A3-E022-FE9C75C8B905 pssh AAAAMnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABISEDItEN25TBKj4CL+nHXIuQU=
big thank bro
bud i want to understand how to if you can give a tip how you do it ?
kind regarts -
Of course you do. Use this https://files.videohelp.com/u/301890/keydump.zip. The content - keydump.py - downloads and examines the first audio fragment for the KID and PSSH.
Noob Starter Pack. Just download any Widevine media! Over 30,000 downloads for V6!.
https://files.videohelp.com/u/301890/hellyes6.zip -
thank you for you answer
i hope its not stupit what i ask becouse i try to with this keydump.py i understand and was befor not know thad we can use the audio for kid or pssh thad was nice info
bud on the python code
i get like this error
python keydump.py
----------------------------------------------- key_ID and pssh dumper -----------------------------------------------
MPD:
It cannot find the path specified in the system.
File "D:\keydump\keydump.py", line 73, in <module>
print(f"\n\nkey_ID: {get_kid()}")
File "D:\keydump\keydump.py", line 44, in get_kid
mymp4dump = subprocess.Popen([mp4dumpexe, FInput_audio], stdout=subprocess.PIPE, stderr=subprocess.DEVNULL)
NameError: name 'FInput_audio' is not defined
i chack my yt-dlp and its installed teh last version and try to get manuel with this
yt-dlp -f 'ba' --allow-u --test --no-warnings 'https://svc40.main.vr.t-online.de/LCID3221228215.originalserver.prod.sngtv.t-online.de/PLTV/88888888/224/3221228215/3221228215.mpd'
and get this result
[generic] Extracting URL: 'https://svc40.main.vr.t-online.de/LCID3221228215.originalserver.prod.sngtv.t-online.de/PLTV/8888...8215/3221228215.mpd'
ERROR: [generic] "'https://svc40.main.vr.t-online.de/LCID3221228215.originalserver.prod.sngtv.t-online.de/PLTV/88888888/224/3221228215/3221228215.mpd'" is not a valid URL. Set --default-search "ytsearch" (or run yt-dlp "ytsearch:'https://svc40.main.vr.t-online.de/LCID3221228215.originalserver.prod.sngtv.t-online.de/PLTV/88888888/224/3221228215/3221228215.mpd'" ) to search YouTube
i not found what i make wrong or what is wrong ?!
Kind regarts -
I have no idea of the errors you make.
[Attachment 74344 - Click to enlarge]Noob Starter Pack. Just download any Widevine media! Over 30,000 downloads for V6!.
this is subscription needed for this site?
I gotten different pssh and kid using my script. like to try to get the key
Init PSSH: AAAAdXBzc2gBAAAA7e+LqXnWSs6jyCfc1R0h7QAAAAHdEC0yTL mjEuAi/px1yLkFAAAAQQgBEhDdEC0yTLmjEuAi/px1yLkFGhRtYWd5YXJ0ZWxlY29tZ2VybWFueSIOcj01MjAwMTI mcz05NTUqBVNEX0hE
KID: dd102d324cb9a312e022fe9c75c8b905 -
i get this with other script becouse it not run with other
Code:url = https://svc40.main.vr.t-online.de/LCID3221228286.originalserver.prod.sngtv.t-online.de...3221228286.mpd psshs = { "edef8ba9-79d6-4ace-a3c8-27dcd51d21ed": [ "AAAAdXBzc2gBAAAA7e+LqXnWSs6jyCfc1R0h7QAAAAG+jCW2U0wZMz9JMUMiInahAAAAQQgBEhC+jCW2U0wZMz9JMUMiInahGhRtYWd5YXJ0ZWxlY29tZ2VybWFueSIOcj01MjAxMjAmcz05NTUqBVNEX0hE" ], "9a04f079-9840-4286-ab92-e65be0885f95": [ "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" ] }
Code:import base64 import json import requests import uuid import xmlschema from http.cookiejar import MozillaCookieJar from urllib.parse import urljoin # Fix MTU fragmentation issues from requests.adapters import HTTPAdapter from requests.packages.urllib3.util.retry import Retry requests.packages.urllib3.util.ssl_.DEFAULT_CIPHERS += ':HIGH:!DH:!aNULL' # Configure max retries globally adapter = HTTPAdapter(max_retries=Retry(total=5, backoff_factor=1, status_forcelist=[400, 429, 500, 502, 503, 504])) session = requests.Session() session.mount("https://", adapter) session.mount("http://", adapter) # Configure proxy if needed (replace None keyword) proxy = None # Examples: proxy = 'socks5h://127.0.0.1:8080' if proxy: session.proxies = { 'https': proxy, 'http': proxy, } # Configure cookies if needed (replace None keyword) cookies = None # Examples: cookies = 'cookies.txt' if cookies: cj = MozillaCookieJar(cookies) cj.load(ignore_discard=True, ignore_expires=True) # Loads session cookies too (expirydate=0) session.cookies = cj xsd = 'http://standards.iso.org/ittf/PubliclyAvailableStandards/MPEG-DASH_schema_files/DASH-MPD.xsd' schema = xmlschema.XMLSchema(xsd) user_agent = 'Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/117.0.0.0 Safari/537.36' def get_pssh_from_data(data): pssh_header = bytes([0x70, 0x73, 0x73, 0x68]) output = {} for count, each in enumerate(data): if data[count:count + 4] == pssh_header: key_system = str(uuid.UUID(bytes=data[count + 8:count + 24])) size = int.from_bytes(data[count - 4:count], byteorder='big', signed=False) pssh = base64.b64encode(data[count - 4:count + size - 4]) output.setdefault(key_system, set()).add(pssh) return output def process_template(template, representation_id=None, bandwidth=None, time=None, number=None): if representation_id is not None: result = template.replace('$RepresentationID$', representation_id) if number is not None: nstart = result.find('$Number') if nstart >= 0: nend = result.find('$', nstart + 1) if nend >= 0: var = result[nstart + 1:nend] if 'Number%' in var: value = var[6:] % (int(number)) else: value = number result = result.replace('$' + var + '$', value) if bandwidth is not None: result = result.replace('$Bandwidth$', bandwidth) if time is not None: result = result.replace('$Time$', time) result = result.replace('$$', '$') return result def get_mpd_from_url(url, headers={}): body = session.get(url, headers=headers).text return xmlschema.to_dict(body, schema=schema, validation='skip', encoding='utf-8') def get_init_urls_from_mpd(url, mpd): output = [] for period in mpd['Period']: for adaptation_set in period['AdaptationSet']: if 'BaseURL' in period: base_urls = [urljoin(url, x) for x in period['BaseURL']] else: base_urls = [url] adaptation_segment_template = adaptation_set.get('SegmentTemplate', None) for representation in adaptation_set['Representation']: representation_segment_template = representation.get('SegmentTemplate', None) for segment_template in [adaptation_segment_template, representation_segment_template]: if segment_template and '@initialization' in segment_template: initialization = process_template( segment_template['@initialization'], representation_id=str(representation['@id']), bandwidth=str(representation['@bandwidth'])) for base_url in base_urls: output.append(urljoin(base_url, initialization)) if 'BaseURL' in representation: for base_url in base_urls: for set_url in representation['BaseURL']: output.append(urljoin(base_url, set_url)) return output def get_pssh_from_inits_urls(input, headers): output = {} for each in input: for key, values in get_pssh_from_data( session.get(each, headers={'range': 'bytes=0-32768'}.update(headers)).content).items(): output.setdefault(key, set()).update(values) return output def get_pssh_from_url(url, headers={}): print('url = ', url) mpd = get_mpd_from_url(url, headers) inits = get_init_urls_from_mpd(url, mpd) psshs = get_pssh_from_inits_urls(inits, headers) print('psshs = ', json.dumps({key: [value.decode() for value in values] for key, values in psshs.items()}, indent=2)) return psshs # Check my IP if proxy: print('My IP is: ', session.get('https://checkip.amazonaws.com').text) # Examples get_pssh_from_url( 'https://svc40.main.vr.t-online.de/LCID3221228286.originalserver.prod.sngtv.t-online.de/PLTV/88888888/224/3221228286/3221228286.mpd', { 'User-Agent': user_agent, })Last edited by senkron24; 15th Oct 2023 at 15:16.
bud i undertand
thare two difrend pssh or kid
mpd is a multi-drm stream which can be decrypted by 2 key systems:
(widevine) edef8ba9-79d6-4ace-a3c8-27dcd51d21ed
(fairplay) 9a04f079-9840-4286-ab92-e65be0885f95
bud still stuck on pssh
Different PSSH in mpd, EME logger and PSSH Box Generator
By Kevste in forum Video Streaming DownloadingReplies: 4Last Post: 31st May 2023, 23:24 -
How to get the PSSH?
By Anonymousdk01 in forum Video Streaming DownloadingReplies: 2Last Post: 28th Mar 2023, 11:06 -
get pssh
By tere1579 in forum Video Streaming DownloadingReplies: 6Last Post: 1st Dec 2022, 23:35 -
Which PSSH is the right one?
By Quint in forum Video Streaming DownloadingReplies: 5Last Post: 24th Oct 2022, 05:39 -
Wrong PSSH?
By Caidking in forum Video Streaming DownloadingReplies: 7Last Post: 20th Oct 2022, 14:47
