I have particular .m3u8 that will only play in VLC and in my browser that has extension. But no where else.
I have tried to streamlink it. Will not streamlink.
How can I make E+ m3u8 so it will play in my panel?
ip restricted
make a script to get m3u8 from the ip of your paneldiscord=notaghost9997 -
Thank you guys for replying.
I recently found a way to get it to work from another site that also has these streams available. Listed below is an example of some sort of extension/prefix they use to get the stream to work. What type of prefix is this?
https://pvxumpmf2yepr6qzx1pu.herokuapp.com/temp/eplus/bitrate.m3u8?hmac=tggB0eEfg%2fKz...Bg3GE9C0%3d&u= <----then the actual m3u8 comes after this.Last edited by membervip39; 18th Oct 2023 at 21:22.
So what I believe happened is that the provider is blocking IP Server. Because I insert the same link, same location, different IP and it works. It also works everywhere else. Thanks for help.
.m3u8 will play only in browser and VLC but will not play in panel
By membervip39 in forum Newbie / General discussionsReplies: 0Last Post: 13th Oct 2023, 15:48 -
m3u8 livestreams do not play on VLC or IINA
By copyist_moth in forum Newbie / General discussionsReplies: 5Last Post: 30th Mar 2023, 01:12 -
Mpd to hls m3u8 panel
By Anonymous149484 in forum Video Streaming DownloadingReplies: 1Last Post: 12th Jun 2022, 10:44 -
Make playlist play in browser's native player
By DWIChannel in forum Newbie / General discussionsReplies: 73Last Post: 19th Sep 2020, 10:58 -
MPEG 2 Extension for VLC? (VLC can't play its own recordings?!?!)
By gastrof in forum Newbie / General discussionsReplies: 17Last Post: 17th Dec 2018, 00:06
