    Oct 2023
    Ukraine
    Hello everyone!
    I need to convert video in format that can be played on DVD player (that installed in autobus) from usb stick.
    But I have no access to this DVD player in order to test it with different files(( Only I have - is the file that played well on this DVD player.
    I've tried to convert my video using FormatFactory app, but there's not enough option to set the same format for encoding as on the good file.
    Also I've installed ffmeg and tried to convert with it, but I had not enough skill with this soft, so I decided to ask some help here..
    Can you help me pls if possible with command for ffmpeg in order to convert my video to same format as in good file pls?
    MediaInfo of good file:
    General
    Complete name               : D:\TMP\Tour_video_001.avi
    Format                      : AVI
    Format/Info                 : Audio Video Interleave
    Format profile              : OpenDML
    File size                   : 1.46 GiB
    Duration                    : 1 h 35 min
    Overall bit rate            : 2 189 kb/s
    Movie name                  : Tour_video_001
    Writing application         : Lavf58.20.100
    Video
    Format                      : MPEG-4 Visual
    Format profile              : Advanced Simple@L5
    Format settings             : BVOP1
    Format settings, BVOP       : 1
    Format settings, QPel       : No
    Format settings, GMC        : No warppoints
    Format settings, Matrix     : Default (H.263)
    Codec ID                    : XVID
    Codec ID/Hint               : XviD
    Bit rate                    : 1 729 kb/s
    Width                       : 704 pixels
    Height                      : 384 pixels
    Display aspect ratio        : 1.85:1
    Frame rate                  : 23.976 (24000/1001) FPS
    Color space                 : YUV
    Chroma subsampling          : 4:2:0
    Bit depth                   : 8 bits
    Scan type                   : Progressive
    Compression mode            : Lossy
    Bits/(Pixel*Frame)          : 0.267
    Stream size                 : 1.15 GiB (79%)
    Writing library             : XviD 67
    Audio
    Format                      : AC-3
    Format/Info                 : Audio Coding 3
    Codec ID                    : 2000
    Bit rate mode               : Constant
    Bit rate                    : 448 kb/s
    Channel(s)                  : 6 channels
    Channel positions           : Front: L C R, Side: L R, LFE
    Sampling rate               : 48.0 kHz
    Frame rate                  : 31.250 FPS (1536 SPF)
    Bit depth                   : 16 bits
    Stream size                 : 305 MiB (20%)
    Alignment                   : Aligned on interleaves
    Interleave, duration        : 32  ms (0.77 video frame)
    Title                       : AC3 5.1 | 640
    Service kind                : Complete Main
    Mar 2008
    In the past when this was popular (20 years ago) the main things affecting compatibility were these two
    which had to be set like this. Lucky, this came with the defaults :
    Other things I can remember - the resolution had to be 720x576 or less,
    bit rate not too high (I used to use constant Quantizer 4 in Xvid)
    and either mp3 or ac3 audio.
    You can use Avidemux to set it up
  3. Why do you want to encode it, if it plays well on the DVD Player?
    Oct 2023
    Ukraine
    I need to encode another video in order to make it playable on DVD player too)
  5. Originally Posted by Keid View Post
    Use clever FFmpeg-GUI.
    Load your video, click main, click encode videostream, set video encoding like in the pic (red marks), click encode.
    [Attachment 74332 - Click to enlarge]
    If done, click encode audiostream, set the encoder to ac3, like in the pic (red mark), click encode.
    [Attachment 74333 - Click to enlarge]
    If done, click multiplex, the new created streams are shown in green, already selected, set avi as container, click multiplex.
    [Attachment 74334 - Click to enlarge]
    Done. You'll find your new compatible video in the target folder.
    Oct 2023
    Ukraine
    Thank you very much guys, it works!)
    Also thanks for Avidemux tool recommendation, it is very usefull!
