    Jan 2015
    Denmark
    Hi,
    I'm on windows 11, trying to capture from vcr through usb-capturing-stick.
    It works, but the quality is pretty bad. Very pixelated because of the MJEG, witch is the only videocodec I can choose?
    It looks like something encoded with only 500 Kbs pr. sek. on "veryfast"
    I've installed K-lite codec pack.
    I use Virtuel-dub. Also when I choose lossfree video, its only about 3 GB pr. hour.
    On windows 10 I could record with about 100 GB pr 2 hours, and I got much better bitrate/quality.
    Is it the stick thats really that bad?
    Why can't I choose other codecs?
    What am I doing wrong here, guys? Please help.
    I only have grafficcard on the mainboard.
    Best regards.
  2. I did this 15 years ago. Because of the slow Pentium II PC, I recorded the video uncompressed and then in a second step converted it to DIVX.
    Aug 2018
    Wrocław
    Originally Posted by bagmand View Post
    Hi,
    Best regards.
    You should also be able to choose uncompressed YUV 422 720x576.
    But yes, this stick is bad anyway.
    Jan 2015
    Denmark
    I can only choose yuv 480x320. And no settings availible. But yes, the stick "Logilink" seems crappy.
    The input is also reallyd bad and pixelated, so I guess I have to spend more on a quality stick, box or whatever you can buy these days?
    Do you have any suggestions to a good one?
    Aug 2018
    Wrocław
    You'll find plenty of suggestions on this forum
    https://forum.videohelp.com/threads/410556-Any-good-USB-capture-devices
    Jan 2015
    Denmark
    Thanks.
  7. Banned
    Nov 2022
    I had a $10 converter that would only allow MJPEG, and would deinterlace to 30p in the hardware. I returned it.
    I suggest trying another device from a reputable brand.
    Jan 2015
    Denmark
    I think I'll go for the Hauppaug usb-live 2.
    But is there different models of this unit?
    Some places it says windows 11 compatibility, and other places only windows vista?
