Apologies if this has been posted in the wrong place.
I have been a long-time user of ImgDrive but I'm having trouble getting anything to mount since I started using Windows 11.
In Device Manager, I can see the "ImgDrive" device under Storage controllers. However, under DVD/CD-ROM drives, the "Yubsoft ImgDrive SCSI CDRom Device" has a yellow triangle on it, and when I click on it, it reads: Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39).
Incidentally, my external USB DVD drive is also refusing to work. It displays the same yellow triangle and message as above.
ImgDrive claims to support Windows 11. Does anybody have any suggestions?
Could it have anything to do with having memory integrity turned on?
Results 1 to 11 of 11
That (mem integrity) or driver signing, is a very good possibility.
Did it get installed BEFORE or AFTER you upgraded to Win11 (assuming you upgraded rather than reimaged from scratch)? My hunch is BEFORE, and so I would test to see if uninstalling, rebooting, then reinstalling might help.
Scott -
It is a fresh installation of Windows 11.
I'd previously (while on Win10) been using an older version of ImgDrive but when I tried to install that version in Win11, it displayed a message stating the the driver could not be loaded due to memory integrity being turned on.
I downloaded the latest version which installed without any issues popping up - but when I try to use it, nothing will mount.
I'm reluctant to turn off memory integrity. -
Just use the windows 11 iso mount.
Works fine here with Windows 11.
Disconnect your external USB DVD drive and delete both entries in device manager
(Yubsoft ImgDrive SCSI CDRom Device and the external USB DVD drive with the yellow triangle).
Then restart your computer and start imgdriveportable.exe.
This will install the driver again. It should work now.
Finally connect your external USB DVD drive. It should be installed well too. -
IMO, Memory integrity screws up a number of apps, and isn't usually necessary, so not a big deal to turn it off.
Scott -
I'm happy to keep it on for the time being but if it causes any further problems I'll certainly consider turning it off.
Windows 11 Mini PC & Wireless Keyboard & Trackpad A Couple Of Problems
By Tom Saurus in forum ComputerReplies: 2Last Post: 24th Nov 2022, 19:34 -
Why opening several Subtitle Edit Windows on Windows 10 slows down...
By robena in forum SubtitleReplies: 1Last Post: 30th Jun 2022, 20:07 -
Windows Movie Maker 2012-in Windows 10
By jastavoss@msn.com in forum Newbie / General discussionsReplies: 3Last Post: 27th Dec 2021, 18:55 -
Softsubs won't appear on Windows Media Player on Windows 10
By aruwin in forum Software PlayingReplies: 7Last Post: 10th Jun 2020, 15:33 -
4K Video Downloader 4.10.1 Portable Windows 64-bit YouTube Problems?
By KermitJ in forum Video Streaming DownloadingReplies: 6Last Post: 27th Dec 2019, 22:36
