Hi.
I have an MP4 UHD Bluray Remux file that seems to have two video tracks, with the 2nd track being a 1080p solid green video with Dolby Vision:
Is this a valid UHD Bluray remux with all original video and Dolby Vision data intact?Code:General Complete name : ***.BDREMUX.2160p.HDR.DV.***.mp4 Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 (mp42/dby1/isom) File size : 46.8 GiB Duration : 1 h 46 min Overall bit rate : 63.1 Mb/s Encoded date : UTC 2019-10-21 14:04:23 Video #1 ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : SMPTE ST 2086, HDR10 compatible Codec ID : hev1 Codec ID/Info : High Efficiency Video Coding Duration : 1 h 46 min Bit rate : 62.6 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.315 Stream size : 46.4 GiB (99%) Default : No Encoded date : UTC 2019-10-21 14:04:23 Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 Codec configuration box : hvcC Video #2 ID : 2 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible Codec ID : dvhe Codec ID/Info : High Efficiency Video Coding with Dolby Vision Duration : 1 h 46 min Bit rate : 65.3 kb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.001 Stream size : 49.6 MiB (0%) Default : No Encoded date : UTC 2019-10-21 14:04:23 Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 Codec configuration box : hvcC+dvcC
By the way, notice the HDR format of the second video track says "EL+RPU" and not " BL+EL+RPU" - I don't know what it means.
This file is played for me as HDR and not DV.
Is it possible to convert it to an mkv file with a single video track that includes the DV data, and without any data loss, so it will be similar to other files I have that are played well as DV?
If so, how?
What I want is something like this (example of a file I have that is played as DV):
Thanks!Code:General Unique ID : *** Complete name : ***.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.TrueHD.7.1.Atmos***.mkv Format : Matroska Format version : Version 4 File size : 77.9 GiB Duration : 2 h 43 min Overall bit rate mode : Variable Overall bit rate : 68.2 Mb/s Movie name : *** Encoded date : UTC 2021-12-14 05:56:16 Writing application : mkvmerge v63.0.0 ('Everything') 64-bit Writing library : libebml v1.4.2 + libmatroska v1.6.4 Video ID : 1 ID in the original source medium : 4113 (0x1011) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible Codec ID : V_MPEGH/ISO/HEVC Duration : 2 h 43 min Bit rate : 56.6 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.285 Stream size : 64.7 GiB (83%) Language : English Default : No Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 1000 cd/m2 Maximum Frame-Average Light Level : 901 cd/m2 Original source medium : Blu-ray
Both remuxes seem ok and have all DoVi data that was originally on disc. You can tell by Profile 7 being mentioned. There is a difference in build-up between the mp4 and mkv though. Note the difference in number of videostreams.
For Dolby Vision on UHDBD, Profile 7 DoVi is used. It consists of two separate .hevc streams that each hold a layer: BL (baselayer) and EL (enhancement layer). The mp4 contains the exact two .hevc streams as they are on disc. For P7 DoVi mkv, the two layers have to be interleaved into one .hevc track. This is - next to decrypting - exactly what software like MakeMKV does. With Profile 7 the RPU (which is Dolby Vision's dynamic metadata) is always carried in the EL.
It's up to a player what container types but also what DoVi profiles are supported. Where a lot of DoVi mediaplayers are able to handle RPU, but often have no support for FEL. Which stands for Full Enhancement Layer: next to RPU, FEL carries additional, differential 10-to-12-bit videodata.
To be complete, in case EL does not have this - thus only carrying RPU - it's called MEL. Which stands for Minimum Enhancement Layer. -
Thanks for the explanation!
Do you know how to convert the first file (with the two video tracks) into the format of the second file (with the one video track), without any data loss? -
First thought and easiest way would be to see if MakeMKV would accept the DoVi mp4 as input. I never tried tbh.
I do a lot of Dolby Vision stuff manually. In this case, I'd first demux the mp4 into elementary streams. The resulting "BL.hevc" and "EL.hevc" I interleave into one hevc-stream with the "mux" command of quietvoids's dovitool:
https://github.com/quietvoid/dovi_tool
This result can be imported into MKVToolNix for creating DoVi P7 mkv. When muxing Dolby Vision, always force-set the "Default duration/FPS" to the proper value.
At the doom9 forums, -QfG- has put much effort in writing scripts that can take over a lot of manual labour.
https://forum.doom9.org/showthread.php?t=183479
Also, you may want to check out the main DoVi thread at the MakeMKV forums:
https://forum.makemkv.com/forum/viewtopic.php?p=141627#p141627
Where member RESET_9999 put a lot of work in his "DoVi_Scripts and Tools". You'll find the link in his signature.
Reading the stream-size of EL in your mp4 data, I think the EL is MEL. So only carrying RPU. In which case you could also opt for creating a Profile 8 DoVi file. P8 is widely used and much supported. With Profile 8 there is no EL; RPU will be carried by the BL (BL+RPU). P8 is considered "equivalent" to P7 with MEL as it holds all video- and DoVi data that was on disc. Native P7 RPU does have to be converted to P8 RPU prior to "injecting" (as it's called) in BL. Which all can be done with quietvoid's dovitool, but the scripts can help you do it maybe easier.Last edited by Ennio; 13th Oct 2023 at 04:24.
Convert mp4 to mkv with track names intact
By magnu in forum Video ConversionReplies: 1Last Post: 31st May 2023, 12:17 -
Edit Video Track Separately From Audio Track in VideoPad
By meandersleut in forum EditingReplies: 0Last Post: 12th Sep 2022, 13:11 -
ffmpeg MKV to MP4 error track 1: codec frame size is not set
By Anonymous543 in forum Newbie / General discussionsReplies: 23Last Post: 4th Mar 2022, 08:06 -
MKV Dolby Vision encodes to MP4 ?
By Fuso in forum Video ConversionReplies: 2Last Post: 16th Mar 2021, 05:06 -
Only single track exporting to WAV from a multi track project.
By solkap in forum AudioReplies: 0Last Post: 4th Jan 2019, 17:28
