Do you lose quality when you break up a DivX into 2 parts using Virtual Dub? It's a direct stream copy right? So does that mean it's copying the exact frames, and no quality is lost?
You are right no quality lost when you split with v-dub. You will lose some when you encode it to mpeg.
yes you will lose quality when converting to mpeg but only if the divx is a dvd rip
We were all NEWBIES once and the only stupid question is the one that's not asked? -
Re-encoding always causes some lost in quaility. DVD rip or no DVD rip. However, if you want to spilt a DivX to encode two (or more) x(S)VCDs you should use the source range command in TMPGenc instead.
It's easier and allows to set up batch encoding. -
Sorry, Vegita-sama, but could you explain better? I usually have bad quality MPEGs when the source is a DIVx file, I wonder if I can use any filter to improve it, or another encoder? What u thing?
I have a question related to this: Is it at all possible to improve the picture quality after or during the encoding process?
You can use filters such as smooth, and noise reduction to make minor improvements. The best way to find out the combination that works for you is to do some tests on a short clip.
Craig
How to reduce filesize and to not lose too much quality?
By xxxThiefxxx in forum Blu-ray RippingReplies: 5Last Post: 9th Aug 2011, 09:48 -
HOw come .iso files lose quality
By ninjinturdle in forum DVD RippingReplies: 2Last Post: 8th Dec 2010, 09:52 -
Increase the bitrate---> Lose Quality?
By mark63534 in forum Newbie / General discussionsReplies: 10Last Post: 21st Jul 2010, 14:36 -
Do i lose any quality doing Blu-Ray to MKV?
By David9799 in forum Blu-ray RippingReplies: 8Last Post: 1st Oct 2009, 22:06 -
Every Time I Crop, I Lose Quality!
By terminalh in forum Video ConversionReplies: 8Last Post: 18th Jan 2009, 14:04
