Is there a way of removing the region lock from a UHD Bluray? DVD fab doesn't remove it, when I rip the disc. Blu-ray Region Code Remover 2.5 gives an error message when I try.
I'm trying to remove the region lock from Talk To Me. It is locked to Region A.
UHD Blu-ray doesn't use region locks. Any UHD Blu-ray disc can be played with any UHD Blu-ray player no matter where the disc was purchased. Something else is wrong.
Are you sure that you have a UHD Blu-ray disc? Purchased UHD-Blu ray movies often include a Blu-ray disc as well as a UHD Blu-ray disc. The Blu-ray disc can be region coded.Last edited by usually_quiet; 8th Oct 2023 at 09:17.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
There are several UHDs that use region locks. Here is a list
https://forum.blu-ray.com/showthread.php?t=334606
If you go to the last page you can see that Talk To Me is also on the list -
One workaround is to use MakeMKV of just the movie as a MKV file. Reading on other sites, the application of zone restrictions was probably an authoring mistake and the disc should be returned as it goes against the official rules for UHD discs. It's probably Zone A (USA) Europe, UK and Australia/NZ are region B
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
The problem with making a mkv is that my player can't handle Dolby Vision with mkv-files. I was hoping to watch this on Halloween. Guess I have to watch it without dolby vision or wait until the replacement discs arrive, assuming they will and they have a replacement program.
Did you try MakeMKV to create a backup as files and folders? I know for certain that MakeMKV can do that. Only DVD bakups are limited to MKV files.
[Edit] It looks like MakeMKV doesn't remove the region code from a file and folder backup. RedFox AnyDVD HD is the only ripper that I found in my seardh which is supposed to remove region coding from Blu-ray and UHD Blu-ray. However, it is provided as an option, not something that is done automatically.Last edited by usually_quiet; 9th Oct 2023 at 21:08.
Convert mkv with Dolby Vision to UHD Bluray
By kallek in forum Authoring (Blu-ray)Replies: 19Last Post: 25th Apr 2024, 06:50 -
Convert-mkv-4k-to-UHD-Bluray
By lcohen448 in forum Authoring (Blu-ray)Replies: 16Last Post: 5th Aug 2023, 03:55 -
Convert mkv 4k to UHD Bluray
By lcohen448 in forum Authoring (Blu-ray)Replies: 1Last Post: 1st Aug 2023, 19:51 -
Why is the JAWS 4K UHD streaming quality, better than my JAWS 4K UHD disc?
By ZackyDog in forum Video Streaming DownloadingReplies: 25Last Post: 28th Oct 2021, 04:23 -
How to rip UHD BluRay to <10GB and get acceptable quality?
By rawyolks in forum Video ConversionReplies: 4Last Post: 18th Jan 2021, 23:26
