I have an MPEG2 format movie that's in 720x480 resolution. DVDit PE says that your Mpeg file needs to be this size in order for it to create a DVD. When I try to create a DVD, it tells me that my Mpeg2 file does not meet the resolution to create a DVD. Has anyone had this type of problem with this program before, and how did you fix it? Any help here would be great.
You probably have a bad horz-vert resolution size indication in the lead header. Get the program DVDPatcher at:
http://kickme.to/DVDPatcher
and use it to examine your headers. If you find that they are other than what you need, you can change them using this prog.
HINT: Start by just changing the first header (seems to be all tha DVDit reads) instead of the entire file. -
Well, I just tried that DVDPatcher a couple of different times, and that doesn't seem to work very well. Thanks though. Anything else?
subtitles with DVDit 6 PRO
By jakewoodblues in forum Authoring (DVD)Replies: 2Last Post: 16th Apr 2010, 13:51 -
Replacement for DVDit Pro HD 6.3 Final
By GrampaD in forum Authoring (Blu-ray)Replies: 2Last Post: 11th Oct 2009, 11:04 -
Subtitle Sync Problems in DVDit Pro
By aquaorbis in forum SubtitleReplies: 0Last Post: 5th May 2009, 22:40 -
Has anyone used Sonic Scenarist or DVDit pro HD?
By jbandy1 in forum Authoring (Blu-ray)Replies: 16Last Post: 18th Feb 2009, 01:08 -
DVDit Pro HD and Sript error in activation
By arturjose in forum Authoring (DVD)Replies: 1Last Post: 19th Nov 2007, 00:51
