Results 61 to 90 of 723
Noob Starter Pack. Just download any Widevine media! Over 22,000 downloads for V6!.
https://files.videohelp.com/u/301890/hellyes6.zip -
Hi LastResort,
I've been able to replicate your error on one of my other PCs. To fix it, I changed that line from :
file = r'file://C:/rClone/FTA/ukfta/my5_dl/config.py'
to
file = r'C:\rClone\FTA\ukfta\my5_dl\config.py'
and it fixed it. -
Hi People,....
This is one of those odd situations that I'm hoping someone else may have come across....
It's a CH5 prog, but the prog end with a ?
Seems that Windows does not like creating files with a "?" in the title.
Everything starts to work, but then I get the following:
18:03:13.344 INFO : Save Name: Captain_Tom_Where_Did_the_Money_Go._S00E01_Captain _Tom_Where_Did_the_Money_Go
18:03:13.344 WARN : MuxAfterDone is detected, binary merging is automatically enabled
18:03:13.482 ERROR: The filename, directory name, or volume label syntax is incorrect. : 'C:\UK-FTA\output\MY5\Captain_Tom_Where_Did_the_Money_Go? ' -
[QUOTE=LastResort;2712304
[/QUOTE]
Linux copes.
But make a small edit to mygetter.py in the my5-dl folder.
[Attachment 74857 - Click to enlarge]
I'll add the change to a next updateCode:show_title = show_title.replace('?','')Noob Starter Pack. Just download any Widevine media! Over 22,000 downloads for V6!.
Thanks for all your work on this works great.
May be outside the scope of the downloader, any chance of adding log in credentials to ITVX to take advantage of the 7 day free trial.
No worries, if not.
Cheers
Steve -
Hi A_n_g_e_l_a, I do not know what did I do wrong?
An All4 Video Search, Selector and Downloader.
Enter a video url with a number of the form xxxxxx-xxx at the end
https://www.channel4.com/programmes/location-location-location/on-demand/75609-004
[!] Failed getting VOD stream !!!
File "C:\UK-FTA\ukfta\c4_dl\C4.py", line 523, in <module>
main(url)
File "C:\UK-FTA\ukfta\c4_dl\C4.py", line 435, in main
encrypted_vod_stream = get_vod_stream(asset_id)
File "C:\UK-FTA\ukfta\c4_dl\C4.py", line 187, in get_vod_stream
brand_title = root.find(asset_info_xpath + 'brandTitle').text
AttributeError: 'NoneType' object has no attribute 'text'
⢿ Loading...
PS C:\UK-FTA> -
Thanks for bringing this up. I noticed this on Tuesday this week.
All4 have made an alteration to the API on the endpoint the C4.py script uses.
We are all getting that error. It comes from a '404 Not Found' response to a request to the video's API.
The API is still there but is refusing to serve, and most likely demanding an authorization token - I haven't checked beyond shoving the url in a browser.
The API has worked well over a long period of time providing high bit-rate 1080p video. It is an Android API so works on TVs and set-top boxes. And it must mean planning and development has taken place to update all the apks in all of the TVs and set-top boxes to the new API standard before this change was made. That takes money.
Someone has put it to me that the rise in availability of scripts, such as mine and StabbedByBrick's, to download everything rapidly, and with a great number of episodes, is possibly the root cause of the API change.
The evidence is only circumstantial and has been suggested to me before. I resisted the idea in the past, in the belief that the costs of change would outweigh the benefits to the providers. But if more and more people use these easy-to-use scripts to take from these sites without consuming their advertising, as they intend, the return on the investment the providers make falls. Also if rights-holders see that All4 is a leaky vessel they may not allow their material to be screened by All4 - again diminishing eyeballs on adverts and revenue. TV platforms are under increasing financial pressure as viewing habits change - they are frightened for their future.
Thus the balance that has pertained for a long while may, indeed, have shifted. But who knows? For a time I'll keep a watch on happenings, though know I am considering freezing further development of UK-FTA for public use.Last edited by A_n_g_e_l_a; 7th Dec 2023 at 05:14.
Ah well, it was great while it lasted. If you do decide to freeze development of the script then I don't blame you, but sincerely thank you for all your work on it and other scripts. It's been great fun.
What a pity, I know this script too late. Thank you so much for your info.
Your hard work and advice has always been very helpful Angela.... the 404 stick hurts, we've had it easy for a while,... and it's very likely that certain eyes watch what happens on f.vh.
Hi Angela,
Is it possible for uk_f_t_a_d_l "a l l 4" section to be modified for a user that already logs in with there own user details... (i often do this if i am only after subs for instance.) but the same log in details are also used on various pieces of hardware equipment around the house. -
Noob alert!!
Can anyone help me with this response for UKTVP - it looks like an issue with at least the N_m3u8DL-RE binary, but I do have that and the others in the UK-FTA directory and I have installed all the other requirements (I believe). Dirs are set in the config and it's finding my keys.
Code:Enter a video URL to download: https://uktvplay.co.uk/shows/bangers-cash-restoring-classics/series-2/episode-1/6326284471112 Using pywidevine WVD on this machine Keys found 50fd1a1516164d45bd8bc1e48e8ce038:23f23415f37befe1399b6fb143ede861 Traceback (most recent call last): File "/Users/mkj/widevine_keys/UK-FTA/ukfta/uktvp/slimuktvp.py", line 147, in <module> download(url) File "/Users/mkj/widevine_keys/UK-FTA/ukfta/uktvp/slimuktvp.py", line 123, in download subprocess.run(command) File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/subprocess.py", line 501, in run with Popen(*popenargs, **kwargs) as process: File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/subprocess.py", line 966, in __init__ self._execute_child(args, executable, preexec_fn, close_fds, File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/subprocess.py", line 1842, in _execute_child raise child_exception_type(errno_num, err_msg, err_filename) FileNotFoundError: [Errno 2] No such file or directory: 'N_m3u8DL-RE' -
Thanks very much for taking pity on me
I've checked the filename as referenced in the sub-scripts and it matches 100% it's in the main UK-FTA directory alongside the menu.py
Any other thoughts much appreciated. I have tried the two OSX versions of N_m3u8DL-RE as I'm running this in Terminal on an Apple M2 Macbook Pro - should I try another version of N_m3u8DL-RE ?? -
Have you tried putting N_m3u8DL-RE into the /usr/binary folder so it's in the PATH?
I can't figure out what's causing this error, just after trying to start the Mux. So I end up with just the MP4 and MP4A files and I then have to put them together manually using ffmpeg.
[Attachment 75680 - Click to enlarge] -
You didn't actually read the error message then?
It tells you on the last line you are missing a needed library file 'libQt6Core'. Find a source for that and install, then see what happens.
I did a quick google search using the last line in your image as my search string and found that python has a qt6 module -
so maybe a
will do it.Code:pip install pyqt6
Is this still working?
I've trying to download this video https://www.channel4.com/programmes/to-catch-a-copper/on-demand/70791-003
But am getting this error:
00:15:51.962 ERROR: One or more errors occurred. (An attempt was made to access a socket in a way forbidden by its access permissions. (ak.dash01.stream.c4assets.com:80))Last edited by Wilkies; 17th Feb 2024 at 19:18. Reason: Formatting
No, it isn't.
I have chosen not to update UK-FTA for further public use. C4 introduced a change recently which broke the C4 downloader but the other channels still work.
Phone-FTA works for all supported channels.
Your file: https://buzzheavier.com/f/GGnBbDBlgAA=Last edited by A_n_g_e_l_a; 18th Feb 2024 at 04:37.
Is a strange error I've not seen before and hints of a local computer issue. Both STV and ITVX still work. Reboot and retry?00:15:51.962 ERROR: One or more errors occurred. (An attempt was made to access a socket in a way forbidden by its access permissions. (ak.dash01.stream.c4assets.com:80))Noob Starter Pack. Just download any Widevine media! Over 22,000 downloads for V6!.
Hot air on the tape.
By Litaiff in forum Capturing and VCRReplies: 2Last Post: 24th Jan 2023, 13:43 -
4K Video Downloader free or money?
By Jomapil1 in forum Video Streaming DownloadingReplies: 8Last Post: 29th Sep 2020, 11:33 -
Simplest and quickest free video downloader ?
By arcadianne in forum Newbie / General discussionsReplies: 28Last Post: 27th Feb 2019, 21:29 -
Using TV downloader
By frankopstaele in forum Newbie / General discussionsReplies: 0Last Post: 2nd Feb 2019, 19:44 -
Downloading Ustream Off-Air / No Videos?
By lemonmellow in forum Video Streaming DownloadingReplies: 1Last Post: 25th Oct 2018, 11:42
