Page 24 of 25
FirstFirst ... 14 22 23 24 25 LastLast
Results 691 to 720 of 723
  1. Originally Posted by iamghost View Post
    @tvdownloaderfan...
    really... why doing it again over and over again
    it same thing with devine and unshackle
    do you think you can download s02e14 STV https://player.stv.tv/summary/disney-moonlighting again with this
    I give you file 720p and 1080p and still not accept it, want to do it on your own
    Maye twice not over and over again as you put it anyway I appreciate you doing the file for me but I was just interested in trying to get it downloading myself but no matter. Just wish I could get TwinVine working. The bit on github makes no sense unless it is actually as someone else told me only for linux users
    Run this line inside the VineFeeder folder:
    cp packages/envied/src/envied/envied-working-example.yaml packages/envied/src/envied/envied.yaml
  2. Originally Posted by A_n_g_e_l_a View Post
    Originally Posted by tvdownloaderfan View Post
    You might be highly intelligent with your programming skills but there's absolutely no need for such insulting rudeness, when someone half or even a third 'answers' without properly explaining and so not making any sense of course I ask again like anyone would. As for taking the piss I don't do that but it seems you do all the time, learn some respect seems you need to girlie
    Ah! jay7 back from the dead! Shame. I liked it better before.
    Absolutely no idea who Jay7 was / is but to say I am an attention seeking troll and to encourage everyone to ignore me is not very kind. I am simply asking for help like many others. I'd like to get TwinVine up and running
  3. Originally Posted by tvdownloaderfan View Post
    Just installed this but how do I run his line ?
    I could be wrong but I think you need to go to the Twinvine folder and go up to the address line and erase what is in there and type cmd and press enter. Then you copy and paste that code and press enter. But I could be wrong.
  4. Originally Posted by Tom Saurus View Post
    This command is simply to make a copy of the file called envied-working-example.yaml and rename the new copy with the file name envied.yaml.
    Do the same thing in windows explorer by right-click on envied-working-example.yaml, "copy", then right-click again on empty space in the window - "paste". Then right-click on the newly pasted file "rename" and call it envied.yaml.
  5. Originally Posted by peterjung View Post
    Thank you for taking the time to explain this.
  6. My GMTEK Mini PC has stopped working. But I have set up Twinvine more or less on my Sister's PC. I notice a Binary Folder in the Envied SRC Folder and I have place the various tools in there. I read here in this thread or at the Github page that a folder should be made for Binaries and that it should be added to the system path. Is this still the case?
    Also I did a test download and it seems to hang when decrypting the audio. Thank you in advance for any advice and guidance.
  7. I am getting this error in Envied:
    [Widevine]: ERROR: unknown command line flag
    'enable_raw_key_decryption' ERROR: unknown command line
    flag 'keys' ERROR: unknown command line flag 'temp_dir'
    Update: I got it figured out. I had to delete a token and I had the wrong file downloaded from the Shaka Packager website. The video was downloaded successfully.
  8. I can't get UK-FTA to work, I use a venv and whenever I click config or one of the services, it opens another terminal instance but outside of the venv which I was initially running from, does anyone else have this issue (attached clip)
    EDIT: Vinefeeder has the same GUI which doesn't have the same problem and works as expected.
  9. Originally Posted by tvdownloaderfan View Post
    It's real simple dude, you're overthinking and not realising how simple it is:
    1. Go to the 'Vinefeeder' folder and open it.
    2. Right click inside the Vinefeeder folder and 'open terminal'
    3. Paste the command:
    Done!
    Alternatively you can do it manually: open the Vinefeeder folder and click through "packages/envied/src/envied/" and you'll see a .yaml file called "envied-working-example.yaml" - make a copy of that in the same folder and name it "envied.yaml".
    Done!
    Feb 2022
    Search the forum first!
    TwinVine running on a portable USB using Arch-Linux, with persistence and disk encryption. The desktop is xfce4
    [Attachment 89961 - Click to enlarge]
    Noob Starter Pack. Just download any Widevine media! Over 22,000 downloads for V6!.
    Dec 2025
    London
    I help this is not a dim question as I have been editing code to try to do it but resort to asking please.
    With TwinVine -- where would I have to make configuration or code edits to get the output videos in mp4 format please?
    Feb 2022
    Write your own batch converter that operates, after download. on a named folder. FFmpeg will do the conversion.
    Dec 2025
    London
    Thanks for advice on save to mp4 -- Copilot also suggested a post save converter.
    I was just checking there wasn't a quick solution like there is in UK-FTA with just a parameter change when calling N_m3u8DL-RE in the python code.
    Thanks again.
  14. Originally Posted by A_n_g_e_l_a View Post
    [Attachment 90336 - Click to enlarge]
    Got it going in docker webtop:ubuntu-xfce, nice work
    Dec 2025
    London
    Tried to get TwinVine working several times but always get this error on BBC - sorry if a basic config error I should have spotted but would be grateful if anyone could help?
    Service selected: BBC
    URL for greedy search shetland
    Unknown error when searching for Shetland
    Preparing to reset Terminal
    Feb 2022
    Well, no wonder! You are using 'URL for greedy search' but not entering any URL are you? URLs start https://www.bbc.co.uk/.....
    You are entering a Keyword 'Shetland' - so on that screen select the Keyword option; see the first two images below;
    [Attachment 90430 - Click to enlarge]
    [Attachment 90428 - Click to enlarge]
    But the better approach, and one or two key presses shorter, is first to put your keyword in the search box and only then click the button for the BBC service
    [Attachment 90429 - Click to enlarge]
    Dec 2025
    London
    Thank you Angela -- I have even surprised myself on how stupid I can be - thank you for your patience. My only defence is that the 1st options appears to work with ITVx, athough not really relevant. Great I can now get the BBC search working by selecting the correct option!
    Again - Thank you!
  18. Just a quick piece of advice required please.... could someone kindly tell me why this odd error would appear when downloading with twinvine::
    [Attachment 90631 - Click to enlarge]
    it's the error 401: unauthorized that i'm curious about.
  19. Originally Posted by LastResort View Post
    I am getting this same error in Envied. I thought it was something I did wrong when trying to configure the .yaml It is interesting you are getting this same error.
    Feb 2022
    Don't panic! Twinvine looks up pssh (for keys) in a remote (online) key Vault to save doing a license request. Presently that key-vault is using a different access key - to stop access - while the owner is doing some back-end work. I understand everything will be back to normal soon. The message is harmless - even if a little alarming..
    Dec 2025
    London
    I thought this was the reason why TwinVine does not download from ITV - I get this error, the file downloads but in merge stage I get code shown on screen and 'Download Failed' and no output file saved. I have tried editing envied.yaml to add ITV log in details in case that was the issue. Here are some screenshots I managed to capture.
    [Attachment 90639 - Click to enlarge]
    [Attachment 90640 - Click to enlarge]
    Do I assume this is a different fault?
  22. Member
    Feb 2022
    Yes
    If you are going to ask for help at the very least say what you were downloading. That allows others to see if they have a fault with that download too - or is the fault just yours?
    From what you post it looks as if shaka-packager is baulking at something. Try setting decryptor to mp4decrypt in the envied.yaml location :- TwinVine/packages/envied/src/envied/envied.yaml or downgrade shaka-packager to version 2..6.1. https://github.com/shaka-project/shaka-packager/releases/download/v2.6.1/packager-win-x64.exe
  23. Member
    Dec 2025
    London
    Sorry Angela, I wasn't following protocol. I was downloading anything from ITV (so I hadn't thought to specify). In this case, just to download something quick I searched 'News'. The first under that which would be the one I downloaded to show the error is [ ] 11, 2:Episode 2, https://www.itv.com/watch/itv-evening-news/2a4545/2a4545a2606, National and international news with reports and analysis from ITVs Correspondents.
    I think the programme I actually wanted when I discovered nothing in ITV was working was -
    [ ] 24, 1:The Devil's Work, https://www.itv.com/watch/midsomer-murders/Ya1096/1a7317a0068,
    Barnaby and Winter hunt for a killer amidst those associated with the Stourwick Estate.
    I had previously left it as didn't want to complain as it could be a change at ITV that will finally be catered for - it was just I thought it may relate to the other posts. I got the programmes through UK-FTA that still works for me on ITV.
    Thanks for the suggestions - I will follow your suggestions to try to resolve.
    EDIT: mp4decrypt seemed to create a file but no video --- just changing shaka-packager to an other I had fixed it --- thank you!!!
  24. ITV worked well for me last night. Thank you Angela for the explanation. Thank you also for your various Downloaders.
  25. Member
    Feb 2022
    Key vault back online. TwinVine services updated
  26. Does Git Pull and UV Snc update Twinvine and the services as well? Thanks in advance for guidance on this issue.
    I went to the Twinvine Folder and went to the address line and typed cmd and then typed:
    git pull
    the program updated then I typed:
    uv sync
    this finished the process and Twinvine is updated which is nice. I noticed a CR in services and thought that meant CRAVE but it is Crunchy Role which I will have to visit that website and see what is there.
  27. Member
    Feb 2022
    noticed a CR in services and thought that meant CRAVE.
    You crave another service? Found it for devine - 9 months without updates - so I have no idea if it works. Added to TwinVine - so yes git pull, and uv sync as always.
  28. Originally Posted by A_n_g_e_l_a View Post
    Thank you!
  29. Hi,
    This evening hasn't went to well, I've tried to install and get vinefeeder works several times but run into the same issue over and over.
    If i start vinefeeder with no envied.yaml config, then I can grab any show from BBC without an issue. No other services work which is as expected.
    If i copy envied-working-example.yaml config over, as per the windows install instructions then I can't grab any show from any service, every attempt returns the following error.
    ❌ Download Failed...
    [WinError 3] The system cannot find the path specified:
    'Temp\\Video_41c2d304.mp4_segments'
    An unexpected error occurred in one of the download workers.
    See the error trace above for more information.
    All configuration options are default as an unmodded envied-working-example.yaml has been copied to envied.yaml
    All toos where installed/downloaded to c:\Tools
