Page 18 of 24
FirstFirst ... 8 16 17 18 19 20 ... LastLast
Results 511 to 540 of 704
  1. Originally Posted by A_n_g_e_l_a View Post
    Originally Posted by Dringostar View Post
    Hi all, this is a begging post ! I’m going away with my wife where there’s no internet. I have already told her I had downloaded the teacher series 2 - 4 episodes. When I actually came to do it yesterday I’ve seen they came be downloaded from my5. I’ve tried the downloaded from Angela but I am not computer literate and really struggling. Can I pull on anyone’s heart strings to download these episodes for me please ? Would really really appreciate it. Thanks so much
    https://buzzheavier.com/f/GX57BECf0AA
    You are a super star thanks so much ! I will download it shortly ! Thanks again !
    Feb 2022
    Search the forum first!
    Originally Posted by BenDWire View Post
    I seem to be having problems with downloaded files from "AllHell3 Gui" called from UKFTA 16_1. I know this is a few versions behind, but I'm not aware anything has changed in this regard (my humblest apologies if this isn't the case!). Any advice would be gratefully received:
    I've downloaded (free) files from discovery+ and the audio goes out of sync seemingly after an advert break (As an example, try the new series of Fifth Gear). I use VLC to play the file, and there isn't anything I can do to solve this. However, playing it via Plex onto my TV, I can pause & restart and the audio sometimes resyncs correctly.
    Can this be corrected during download? I tend to select video at 720p with the lowest bitrate for this kind of programme, but are there any other options I can apply? Failing that, is there a way to post-process the file once downloaded?
    Not really an allhell3 problem; it decrypts. Only you are unhappy with what it decrypts. It would seem your audio stream has timing gaps for adverts to play - unusual but it happens.
    You might choose another stream - use the manual download option - select the text-box labelled 'N_M3u8DL-RE Command' paste the contents to a terminal window and run it. Select an alternative stream for both audio and video.
    If that doesn't work, ask in another videohelp forum - one with AV specialists in.
    Noob Starter Pack. Just download every Widevine mpd! Not kidding!.
  3. Thanks for the advice Angela. I'll keep turning over the rocks until I find a solution!
  4. Hi all,
    I don't suppose you would know why certain episodes of a programme I am trying to download are failing with the following error?
    ? : 1
    [!] Failed getting VOD stream !!!
    File "G:\UK-FTA\ukfta\c4_dl\chan4_loader.py", line 469, in <module>
    myAll4 = C4.main(url)
    File "G:\UK-FTA\ukfta\c4_dl\C4.py", line 565, in main
    encrypted_vod_stream = get_vod_stream(target)
    File "G:\UK-FTA\ukfta\c4_dl\C4.py", line 233, in get_vod_stream
    uri = myjson['videoProfiles'][0]['streams'][0]['uri']
    KeyError: 'videoProfiles'
    It seems to be only couple episodes in each season of this particular show. Apologies if this is somehow obvious, I've only started using this script/programme a few days ago.
    Feb 2022
    Originally Posted by Jason-118 View Post
    Hi all,
    ? : 1
    Jason, Its always a good idea to post the video url so other may try it.
    Sometimes on C4 an episode will be listed but it won't actually be available. It may be waiting for it to air first. So wait a day or so and try again. Or post the link and others may check it for you.
  6. Hi Angela, thanks for the quick response.
    The show itself is quite old and should have been aired at some point. I'm able to stream these episodes fine, but for some reason the following episodes won't download using UK-FTA.
    https://www.channel4.com/programmes/spaced/on-demand/26708-002
    https://www.channel4.com/programmes/spaced/on-demand/26708-006
    https://www.channel4.com/programmes/spaced/on-demand/29570-003
    https://www.channel4.com/programmes/spaced/on-demand/26708-004
    Thanks for your help.
    Feb 2022
    Yes I get an error too. I'll put it on the to-do list. Meanwhile if you need them urgently AllHellGui, with you doing a bit of fetching, will get keys and download for you.
  8. Hi Angela,
    I have managed to get all the episodes from C4 using AllHellGUI, like you suggested.
    I've also noticed AllHellGui seems to be getting these episodes at a higher quality compared to UK-FTA.
    Is there anyway I can ensure the quality UK-FTA downloads are the highest? I only ask as I'm downloading other shows from the BBC and the quality doesn't seem consistent between episodes, I've also tried using the AllHellGui process with the BBC shows but I can't seem to find the ''cURL of License Request'' like I did with the C4 site.
    Thanks.
    Feb 2022
    BBC isn't encrypted so it doesn't need keys.
    UK-FTA downloads the highest quality on web endpoints. So I am unsure as to why you are getting better with AllHell3. AFAIAA both provide 1080p on modern stuff. Quality maybe lower on historical programming.If it's watchable I don't get too hung up on quality.
  10. Sorry @A_n_g_e_l_a I've found another small problem.
    BBC again, Ludwig - UK-FTA can't download episode 1 as it's not got any subs associated with it. All other episodes are fine.
    ⡿ Loading...INFO: Processing tv: 'Ludwig: Series 1 - 01. Episode 1 (m0022ww3)'
    INFO: Subtitles not available for version(s): original
    path empty or file not exists!
    Feb 2022
    Then just try iplayer directly.
    get_iplayer --pid m0022ww3
  12. @A_n_g_e_l_a I already had, and had sorted the issue for me. I was simply making you aware of the issue, was all.
    Feb 2022
    Thanks Akirainblack. The BBC is well known for a messy back-end - to coin a phrase - and I could go mad trying to generalize code to cope with every BBC misconfiguration. It the fault was for a large set of videos not downloading it would be worth the time and effort.
  14. @Akirainblack - I used UK-FTA and all episodes downloaded as usual! Maybe they fixed it?
  15. @A_n_g_e_l_a yes, I completely understand, but if I don't flag it you won't know. Also if I flag it, people will hopefully read and see it's a known issue with the BBC. As @tenxob has said they've fixed it (and I've since checked and confirmed) it's yet another example of the incompetence of the BBC.
    Feb 2022
    Absolutely: thanks for reporting.
  17. Hi Angela.
    When I select MY5 from the menu it brings up the error :
    Extra data: line 1 column 4 (char 3)
    If I run the my5_loader.py directly it works fine. Just thought I'd mention it.
  18. Member
    Feb 2022
    Originally Posted by peterb999 View Post
    Hi Angela.
    Thanks Peter. I see nothing like that - you using the latest?
  19. Hi Angela. I got the error and then updated to the latest version and still get the error. I have two windows machines and get the same error on both which is a bit odd. Have a feeling it's maybe something I've done. When I searched for the error on the forum I found that the same error was happening for someone using Devine (post 833 in the devine thread). Very strange - when I use Devine I don't get that error.
    Like I say though, it works fine using the direct my5 script so it doesn't matter. I'm just very grateful to be able to use the tools you provide, it's a golden age of TV for me at the moment, so many things to watch and so little time.
    Feb 2022
    Hi Peter, sounds strange. I've a virtual Windows instance so I'll run it through that tomorrow and check. As for golden age - I'm finding the more I'm actually able to download, the less I do. YouTube seems to be gaining more of my attention.
    Feb 2022
    Peter, I've just checked on Windows 11 and I have no issues. Most likely you have a bad python package somewhere in the chain. I'm not sure if you use python environments - one for Devine and another for UK-FTA. If not it may be a good idea, so that each keeps its own packages and they will not get updated or downgraded by other scripts.
    If you need to find out how to use environments, it is really very easy - do a VH search for 'Beyond WKS-KEYS' ... setting up envs is in that.
  22. Thanks Angela. I'll have a go with using environments.
  23. Member
    Feb 2022
    Channel 5 seems to have changed something about the mpd; the downloader no-longer functions. While waiting for a solution AllHell3Gui works, with a little more effort.
  24. Really nice tool. Took a moment of setup, making sure all tools were on PATH, etc. but once configured it's a breeze. Thanks for your work!
    I do find myself remuxing each file to my taste though, so would be nice to have a flag to not merge the files after downloading.
  25. Member
    Feb 2022
    I am just so fed-up with with what goes on here these days.
    There is the occasional script-kiddie dropping scat everywhere, desperately trying to build a reputation.
    There is the idiot that takes my code and tries to pass it off as their own - talking about you @imr_salah. If you re-use code of mine - just give credit, then I don't mind.
    There are the permanently-baffled who will not be guided.
    There is a continuous stream of newbies who think everything about DRM should be revealed to them in a two line sentence just for the want of then asking in a new thread.
    And there are those forever dissatisfied with the code I produce for free. They are scripts of source code; alter them to your liking! And if you cannot do that - then put up with them; it is not in my remit to teach you python. I was 76 two years ago when I started to learn python -if a weak and feeble woman can do it, what the heck are the rest of you faffing about at?
    I will be taking a break from VH for a while.
  26. I'm sorry to hear that Angela. You will be greatly missed and I hope that it is only a short break.
    Your scripts are great and it's a shame that not everyone is appreciative of the work you provide free. Hope you're ok.
  27. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    That's unfortunate.
  28. Hope you come back soon your scripts and advice are invaluable.
    Illegitimi non carborundum
  29. Originally Posted by A_n_g_e_l_a View Post
    That's a shame, and I'm sorry that other users have caused this. But please know that the vast majority of us on this thread appreciate all the hard work you have put into UKFTV.
  30. Originally Posted by A_n_g_e_l_a View Post
    I've found that if you copy ffmpeg, mp4decrypt, N_m3u8DL-RE, and shaka-packager into the my5_dl folder and then run my5_loader.py directly from inside that folder it will work.
    I've tested on "The Teacher" and it is downloading no problem.
    But I cannot get it to work via the main menu.py, whenever I choose My5 I get the error "Extra data: line 1 column 4 (char 3)"
    Edit to add - on line 39 of menu.py change UPDATE = True to UPDATE = False and it will work just fine
