Hello,
Anyone knows if according to the specs, a DVD-Video should have ISO (Bridge) Level1 or Level2?
Some apps like Nero allows to select between Level1 and Level2 for the ISO file system of Video-DVD discs.
Nero does not support Level3 so no idea if not supported in DVD-Video or not supported in Nero.
Thanks for advise.
If you want your dvd to play in a stand-alone unit you require MAXIMUM compatability.
The main difference between level 1 and level 2 is the number of letters per filename (8+3 for level1 or 31 for level2) But dvd players ignore ISO (9660) and actually use the UDF format. And Nero is now reknown for creating non-standard disks.
If you have your file/folder structure just use imgburn
video at ground level made easy
By realspeed in forum Newbie / General discussionsReplies: 0Last Post: 10th Mar 2022, 13:01 -
Video Level interpretation in Adobe Premiere
By joelmartin in forum EditingReplies: 0Last Post: 2nd Mar 2021, 05:03 -
NASA level video archival documents.
By digicube in forum RestorationReplies: 6Last Post: 7th Mar 2019, 04:53 -
4K Video Downloader's quality level : real download or upsampling ?
By Captain'Flam in forum Video Streaming DownloadingReplies: 3Last Post: 29th Jan 2019, 11:25 -
Level Spoken audio across video
By BobAchgill in forum Newbie / General discussionsReplies: 3Last Post: 20th Jan 2019, 01:40
