Hello,
I am trying to reduce my movie library size and have always kept all English AC3, DTS, DTS-HD MA, TrueHD and Atmos tracks, but I think I can save space by just keeping the best quality track as I believe they will play in receivers that don't have DTS, DTS-HD MA, TrueHD and Atmos capability. I read somewhere that they have the AC3 inof built in or they will play in receivers without DTS. Is this the case? Can I safely save space by omitting the AC3 tracks?
Did you ever compared for example AC3 and DTS or DTS-HD MA and TrueHD? If there is no significant difference in terms of content then i would keep smaller version of audio (so AC3 over DTS) .
That pertains to authored dvd/blu-ray where ac3 are kept to keep disc playable in most settings,if for just mkv/mp4 playback then just use the best audio your receiver can play
Op can always make an ac3 from the audio he keeps if ever needed.
Thank for the responses! They are very much appreciated! johns0 makes a good point of being able to create another audio from the lossless source, which you cannot do the other way around. I can tell the difference being an ex-audio engineer. Not only is the quality better but there are less artifacts.
If preserving 3D audio is important to you, I don't think audioformats like Dolby Atmos and DTS:X can be recoded while keeping trajectory data and target audio packets. At least not with freeware.
When encoding with a "lossy" codec, you may want to consider using EAC3. In my experience it sounds better than AC3 at equal bitrate. And which for EAC3 isn't limited to 640 kbps.
Need help/guidance converting TrueHD audio track in an MKV to DTS-HD.
By fluxcapacitormb in forum Newbie / General discussionsReplies: 12Last Post: 8th Oct 2023, 03:51 -
How to change audio speed starting from DDP, DTS-MA, AC3 or DTS core?
By precipizio in forum AudioReplies: 0Last Post: 22nd May 2022, 09:28 -
DTS to AC3 whilst keeping all existing tracks
By ddeconin in forum AudioReplies: 8Last Post: 1st Sep 2021, 04:28 -
Convert 7.1 TrueHD audio track to 5.1 DTS, keeping same video in MKV?
By BinaryDad in forum Video ConversionReplies: 2Last Post: 17th Feb 2019, 22:49 -
Are there any pros in keeping a DTS audio track if a DTS-HD is available?
By alexd15 in forum Authoring (Blu-ray)Replies: 3Last Post: 13th Feb 2019, 05:22
