Page 2 of 5
Results 31 to 60 of 127
  1. Originally Posted by PSXman_uk View Post
    PS C:\Scripts\env\Scripts> python l3.py
    PSSH? AAAAWHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADgIARIQ86Ys7iUsS2edueV7RzCVFyIgQjVhTjlVUGlsYmhBMGFSdE1JbThrV29GNWxVWTdHNTI4AQ==
    License URL? https://cbsi.live.ott.irdeto.com/widevine/getlicense?CrmId=cbsi&AccountId=cbsi&SubCont...c0d7fa%22%2Csu
      File "C:\Scripts\env\Scripts\l3.py", line 33, in <module>
        licence.raise_for_status()
      File "C:\Users\psxma\AppData\Local\Programs\Python\Python312\Lib\site-packages\requests\models.py", line 1021, in raise_for_status
        raise HTTPError(http_error_msg, response=self)
    requests.exceptions.HTTPError: 403 Client Error: Forbidden for url: https://cbsi.live.ott.irdeto.com/widevine/getlicense?CrmId=cbsi&AccountId=cbsi&SubCont...c0d7fa%22%2Csu
    Get an error anybody know whats causing this please
    You did use the authorization header, didn't you?
    'authorization': 'Bearer eyJ...'
  2. Code:
    # enter special header values here  in the form  'token':  ' value',   each on one line -  remember the quotes and the comma!
    headers = {
    'authorization': 'Bearer eyJ...,
    SyntaxError: unterminated string literal (detected at line 8)
  3. i think you know that 'eyJ....' means you should replace it to your own token, right? it is a long long string you should paste, not just paste 'eyJ....'
  4. so i will give you the exactly headers.py example which you can use directly, just copy and paste it in your headers.py:
    remember use US vpn.
  5. Image
    [Attachment 77350 - Click to enlarge]
    So if I get this right I don't change the l3.py script itself just create a headers.py in the script directory inside the env leave the l3.py as A_N_G_E_L_A wrote in the example
  6. Originally Posted by PSXman_uk View Post
    If you have the updated pywidevine script that uses a .wvd file, the 'headers' is defined inside the script. Old WKS-KEYS imported headers from an external headers.py file.
  7. it does use the .wdv file google_aosp_on_ia_emulator_14.0.0_f22c747e_4464_l3 .wvd ill try the old version as well see if either works at te moment they dont
    in WKS-KEYS get token expired the other one just error's out
  8. Originally Posted by PSXman_uk View Post
    Didn't realize we were on the Beyond WKS-KEYS thread. Well, then of course you need to put your headers there:
    headers = {
        'Accept': '*/*',
    Always make sure you use a fresh token and that your python script is indeed using your US proxy for the request.
  9. Code:
    headers = {
        'Accept': '*/*',
        'authorization': 'Bearer eyJhbGciOiJIUzI1NiIsImtpZCI6IjNkNjg4NGJmLWViMDktNDA1Zi1hOWZjLWU0NGE1NmY3NjZiNiIsInR5cCI6IkpXVCJ9.eyJzdWIiOiJhbm9ueW1vdXNfVVMiLCJlbnQiOlt7ImJpZCI6IkFsbEFjY2Vzc01haW4iLCJlcGlkIjo3fV0sImlhdCI6MTcwOTE5MTAzNiwiZXhwIjoxNzA5MTk4MjM2LCJpc3MiOiJjYnMiLCJhaWQiOiJjYnNpIiwiaXNlIjp0cnVlLCJqdGkiOiJmMjVmMjI1Zi03MzVmLTQ4NjQtYTIwZi0wZjA0YjczZGNkNjEifQ.Hw06vcq9iy8db6ZJWbhZFFK9g2mKdp0iVv8Wn3tNebk',
    Is this right ?
  10. Originally Posted by PSXman_uk View Post
    headers = {
        'Accept': '*/*',
    Is this right ?
    Looks right except for the fact that you don't need the 'Accept' header (it might not make a difference, but sometimes the auth header alone is better). Also the "enter special header values here" line seems uncommented (#), but maybe you just didn't copy-paste the #.
  11. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    for CBS I don't use a VPN but a socks5 proxy, and even then only for the key request. The other stuff is not geoblocked.
    You could have a look at these and see if any of them work for you
    http://free-proxy.cz/en/proxylist/country/US/socks5/ping/all
  12. The weird thing with this is if you get the keys you can dl without any proxy flat out in my case using N_m3u8DL-RE but I cant get either wskeys or pywidevine to work correctly even though I'm sure I have al it requires from reading and implementing all the setup as per the stickies.
    I always appreciate the help and am sure it must be something simple at my end just cant see what yet.
    Thank you all
  13. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    Thank you all
    Have you succeeded in getting keys for any other website with that CDM or script? Just to make sure and start from the basics.
  14. Code:
    PSSH? AAAAMnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABISEJvtNKDVg04WusufcGXcYkE=
    License URL? https://cassie.channel5.com/api/v2/licences/widevine/491/C5480740001?expiry=1709299017...5c%22%2Cst%3Dv
    --key 9bed34a0d5834e16bacb9f7065dc6241:7474a6901d6ff87704a95b3cea023b6a
    --key 686501a746625c8dd97e2230e8758173:7474a6901d6ff87704a95b3cea023b6a
    Channel 5 video
    PS C:\freevine\WKS-KEYS> python l3.py
    PSSH: AAAAgHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAGAIARIQuKtAKAO+uOe7zcorjmj1hxoMbWVkaWFraW5kbmJhIjpOQkFfMjAyNDAyMDYyMjM1TkJBX19fX19WSURFT1NfX05CQUVfMjcxOTg0MV9KaXRwX1JlYWNoX0hEMgA=
    License URL: https://cassie.channel5.com/api/v2/licences/widevine/491/C5480740001?expiry=1709299017&tag=66626337656363333531396165613866376636383237653236356334636333323935353766353162&CMCD=ot%3Dk%2Csf%3Dd%2Csid%3D%22922100b6-9e1e-4f5c-b336-4fe39094ac5c%22%2Cst%3Dv
    --key 66aabae3f86e8d1dc4157879c6d2e239:7474a6901d6ff87704a95b3cea023b6a
    Feb 2022
    Search the forum first!
    Channel 5 video
    Just how your questions relates to any of the initial topic I fail to see. Channel 5 video and l3.py for heavens sake!! Its been done to death on the forum. Use the SEARCH function! The keys you have are spoofs from C5 to frustrate you. L3 .py cannot be used there. The request is more complex and needs extra data sent. Why didn't your reading discover that?
    Do some research ; then ask questions, if you must, in your own thread?
    Then hopefully I won't keep getting pinged by this site announcing a 'reply' when in fact it is no such thing.
    Noob Starter Pack. Just download any Widevine media! Over 22,000 downloads for V6!.
    Mar 2024
    bejing
    headers = {
        'Accept': '*/*',
    Is this right ?
    I also encountered this error code
    requests.exceptions.HTTPError: 403 Client Error: Forbidden for url: https://ottapp-appgw-amp.nba.com/v1/client/get-widevine-license?ownerUid=azuki&mediaId...3&is_dvr=false
    but my header is‘t authorization,how i slove this problem.
    Feb 2022
    You guys need to use httptoolkit and watch the interaction as a browser loads the page. You'll be able to see the JSON exchange (probably) and headers. Then you can answer your own questions.
  18. Member
    Mar 2024
    bejing
    Video url ?
    This url:https://www.nba.com/watch/video/2016-dunk-contest-lavine-vs-gordon-best-ever
    Pssh:AAAAgHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAGAIA RIQlk9C5GY4kyszQnRh8TZFnxoMbWVkaWFraW5kbmJhIjpOQkF fMjAyMzAxMjkwOTM3TkJBX19fX19WSURFT1NfX05CQUVfMjYzM Dk0MV9KaXRwX1JlYWNoX0hEMgA=
    license url:https://ottapp-appgw-amp.nba.com/v1/client/get-widevine-license?ownerUid=azuki&mediaId...3&is_dvr=false
  19. Originally Posted by jay_670 View Post
    Video url ?
    You're already getting support here, don't post the same problem in multiple threads.
  20. Anonymous
    Guest
  21. Code:
    (env) C:\Users\Admin>pywidevine create-device -k device_private_key  -c device_client_id_blob -t ANDROID -l3 -o WVD
      File "C:\Users\Admin\AppData\Local\Programs\Python\Python37\Lib\runpy.py", line 193, in _run_module_as_main
        "__main__", mod_spec)
      File "C:\Users\Admin\AppData\Local\Programs\Python\Python37\Lib\runpy.py", line 85, in _run_code
        exec(code, run_globals)
      File "C:\Users\Admin\env\Scripts\pywidevine.exe\__main__.py", line 4, in <module>
      File "c:\users\admin\env\lib\site-packages\pywidevine\__init__.py", line 5, in <module>
        from .remotecdm import *
      File "c:\users\admin\env\lib\site-packages\pywidevine\remotecdm.py", line 8, in <module>
        import requests
      File "c:\users\admin\env\lib\site-packages\requests\__init__.py", line 43, in <module>
        import urllib3
      File "c:\users\admin\env\lib\site-packages\urllib3\__init__.py", line 42, in <module>
        "urllib3 v2.0 only supports OpenSSL 1.1.1+, currently "
    ImportError: urllib3 v2.0 only supports OpenSSL 1.1.1+, currently the 'ssl' module is compiled with 'OpenSSL 1.1.0i  14 Aug 2018'. See: https://github.com/urllib3/urllib3/issues/2168
    Sorry, I dont know how to solve this problem?
  22. Originally Posted by zhoubo518 View Post
    I'm not sure but try running these commands
    pip uninstall urllib3
    pip install urllib3==1.26.7
    click click2
    If I/my posts ever helped you, and you want to give back, send me a private message!
  23. Member
    Feb 2022
    Remove the red minus and try again.
  24. Originally Posted by [ss]vegeta View Post
    INFO:root:pywidevine version 1.7.0 Copyright (c) 2022-2024 rlaphoenix
    INFO:root:https://github.com/devine-dl/pywidevine
    Usage: pywidevine create-device [OPTIONS]
    Try 'pywidevine create-device --help' for help.
    Error: key: Not a path to a file, or it doesn't exist.
    Thanks, but it doesnt work. WDV is empty folder. No device_private_key and the device_client_blob found and how to find device_private_key and a device_client_blob?
  25. Originally Posted by A_n_g_e_l_a View Post
    (env) C:\Users\Admin>pywidevine create-device -k device_private_key -c device_client_id_blob -t ANDROID l3 -o WVD
    Error: Missing option '-l' / '--level'.
    No work too.
  26. Member
    Feb 2022
    No work too.
    Sorry bad advice!! The minus is required.
  27. Member
    Feb 2022
    Are you saying you do not have your own device_private_key and a device_client_blob
  28. Originally Posted by A_n_g_e_l_a View Post
    Yes. How can I get these files?
  29. Member
    Feb 2022
    Well you can start by being a bit more awake. The very first post in the forum is https://forum.videohelp.com/threads/408031-Dumping-Your-own-L3-CDM-with-Android-Studio
