Hi, I never done it before, I'm not sure what is the correct procedure to use when I have to deal with multiple logos.
these "mask.bmp" have the same name in the ss, but I renamed them to mask1 and mask2.
have I to create the mask1, then the mask2 or both in the same command line?
what's the syntax?
then about removing logos, how? as usual with 2 different lines at the same time?
edit: ok, nvm, it works that way, I used "Impaint" instead of "Deblend" but those damn logos are hard to remove.
some frames have bubbles.. I have to settle with it.
I don't see any images or files.
yes, you're right, I've delete it.
here's the code:
Code:LoadPlugin("C:\\\\util\MeGUI-2913-64\tools\lsmash\LSMASHSource.dll") V=LWLibavVideoSource("C:\\DVB-T\TS cut\MKV\-cut.mkv") A=LWLibavAudioSource("C:\\DVB-T\TS cut\MKV\-cut.mkv") V=V.AssumeFPS(25) V=AudioDub(V,A) V=V.propDelete("_FieldBased") V=V.crop(0, 130, 0, -130) V=V.Loop(0,31714,40540) #spot V=V.Loop(0,66830,75781) #spot V=V.Loop(0,124429,133430) #spot V=V.Loop(0,0,373) # cut intro #V=V.InpaintLoc(Loc="194,0,-1578,-804") # logo borders #V=V.InpaintLoc(Loc="1696,784,-120,-0") # logo borders #V=V.InpaintLoc(Loc="174,0,-1558,-784") # +20px #V=V.InpaintLoc(Loc="1676,764,-100,-0") # +20px #V=V.InpaintDelogo(mask="C:\\\DVB-T\TS cut\.mask\mask1.bmp", Automask=1, Loc="174,0,-1558,-784", Analyze=2,NoBorderAt="top") #V=V.InpaintDelogo(mask="C:\\DVB-T\TS cut\.mask\mask2.bmp", Automask=1, Loc="1676,764,-100,-0", Analyze=2,NoBorderAt="bottom") V=V.InpaintDelogo(mask="C:\\DVB-T\TS cut\.mask\mask1.bmp", Loc="174,0,-1558,-784", Analyze=2, Mode="Inpaint",NoBorderAt="top") V=V.InpaintDelogo(mask="C:\\DVB-T\TS cut\.mask\mask2.bmp", Loc="1676,764,-100,-0", Analyze=2, Mode="Inpaint",NoBorderAt="bottom") #V=V.SelectRangeEvery(800,20) V=V.bbmod(0,1,0,0,128,8) #V=V.Waveform(window=16, zoom=64, under=true) Return V.Prefetch(7)
Issue with AvsPmod/InpaintDelogo
By Hakunamatata67 in forum SubtitleReplies: 7Last Post: 31st Jul 2023, 08:24 -
InpaintDelogo error message
By Hunk91 in forum RestorationReplies: 11Last Post: 17th Jan 2023, 10:49 -
InpaintDeLogo - logo across crop
By maudit in forum EditingReplies: 15Last Post: 9th Nov 2022, 13:36 -
[help] InpaintDelogo help
By maudit in forum EditingReplies: 14Last Post: 2nd Sep 2022, 05:04 -
InpaintDelogo
By JAX75 in forum Newbie / General discussionsReplies: 39Last Post: 27th Oct 2021, 11:29
