Hello VH,
I come to you with a problem that may be a quick one for someone else to solve or diagnose, but which has taken hours and hours out of my life:
https://drive.google.com/file/d/14ZaVGyq22LfqOmf8hy6Q43KxbqGsc_hi/view?usp=drive_link
Above is a link to a broken streamrip of an NCAA basketball game, broadcast on ESPN several years ago at https://www.espn.com/watch/player/_/id/3245277 (no longer hosted). The video and audio remain in sync until about the 55:28 mark, when, for a reason I cannot fathom, as another set of commercials begins to play, the video plays at 2x speed while the audio remains unchanged. Thus begins an AV de-syncing that only gets worse as the file progresses, with each commercial break behaving the same, and the audio lagging further and further behind.
When I try to manually resync the lagging audio in VLC, to be able to clip out the portions of the broadcast I need, the video freezes while the audio continues, and the program must be restarted. If allowed to play without messing with any audio delays, the video doesn't freeze, except at the final frame, while it waits for the now thoroughly lagging audio to "finish up." This is true both for the file linked above, and for no less than three separate versions I've run through Handbrake using different combinations of encoding settings.
Continuing to try and fail at fixing this is hurting my brain. I'd be thrilled to end up with anything from one large file to multiple smaller files, so long as all the sync issues are eliminated and the file or files are stable enough to be clipped at the appropriate timestamps. FWIW, VideoRedo crashes instantly upon beginning to navigate through the file, and TS Doctor says "File is encrypted. Process Aborted!" upon opening. MediaInfo located here: https://pastebin.com/B3pYycj3
Any and all help is greatly appreciated.
Cheers,
-newmy51
Results 1 to 1 of 1
Espn Plus Download with N_m3u8DL-CLI
By Coledemon97 in forum Video Streaming DownloadingReplies: 2Last Post: 10th Jan 2023, 04:52 -
How to repair MP4 files with corrupted frames
By ridibunda in forum Video Streaming DownloadingReplies: 21Last Post: 1st Mar 2022, 06:02 -
Need help downloading this [ESPN+]
By GEOLINK in forum Video Streaming DownloadingReplies: 8Last Post: 13th Jan 2021, 16:00 -
NCAA Tournament (March Madness Live)
By hj83 in forum Video Streaming DownloadingReplies: 2Last Post: 27th Mar 2019, 13:53 -
Problem with Watch ESPN reruns on Amazon TV firestick.
By tigers37 in forum Video Streaming DownloadingReplies: 1Last Post: 3rd Jan 2019, 18:34
