I am using software that generates perfectly valid DVD-compatible MPG file (although with BFF for some reason, but I suppose it is not prohibited for DVD), and the video is actually interlaced, but is flagged progressive. I can deinterlace it in VirtualDub, but media players show combing because they think the file is progressive. I can adjust VLC, still I would prefer the header to be correct.
Can someone help me, how to patch the header from progressive to interlaced. Also, just in case how to specify either TFF or BFF.
Thanks!
https://www.videohelp.com/software/DVDPatcher
https://www.videohelp.com/software/MPGPatcher
https://www.videohelp.com/software/Restream (probably the best for your purpose)
For DVD you may (?) also have to modify the IFO
https://www.videohelp.com/software/IfoEdit
or for VOBs:
https://www.videohelp.com/software/VobEdit
or take a look at
https://www.videohelp.com/software/PgcEdit
DVD can be TFF or BFF
Someone else might help with an ffmpeg commandline .......Last edited by Sharc; 4th Oct 2023 at 02:35.
Restoring Interlaced master that should have been progressive
By Jan Tokki in forum RestorationReplies: 7Last Post: 20th Jul 2022, 15:30 -
Is it possible to transfer progressive video file back to interlaced?
By anonymoustly in forum MediaReplies: 15Last Post: 20th Mar 2022, 15:20 -
Interlaced Artifacts on Progressive Video?
By TheKCVault in forum Newbie / General discussionsReplies: 3Last Post: 28th Apr 2021, 17:52 -
Interlaced video incorrectly called progressive
By barmah in forum Video ConversionReplies: 3Last Post: 8th Jul 2020, 03:39 -
ffmpeg changes interlaced to progressive
By SF01 in forum Video ConversionReplies: 12Last Post: 30th Mar 2020, 09:51
