I have some old tapes i would like to digitalize using OBS. While the video displays fine with colors etc, i get no audio. I've done this before, but that was so many years ago that i've forgotten what i must do in order to get audio to work...
The audio (and ofc the video too) works fine on the camcorder itself (when i flip-out the its screen), but i just cannot get the audio to work in OBS...
I have a sony dcr130e, connected to a cheap plexgear moviesaver 600 with a mini jack to 3 rca-cable (from the A/V OUT on my camcorder) that's then connected to my pc. This method is what i have used before.
I've not muted anything.
In OBS, i have tried to turn on Monitor and Output in Audio Monitoring in Adv. Prop., but no success...
I have other files on my pc, so the audio works fine on my windows 10 pc.
Any ideas on how i can get the audio to work on my pc as well?
DV cassettes are digital, there is no need to digitize an already digital signal, What you are doing is converting digital to analog by using the camcorder analog output and then converting it back to digital using a capture device. Instead, connect your DV camcorder to computer using a firewire port (a.k.a iLink) and use a program called ScLive to transfer the digital data on tape into computer without loss of quality.
OBS vs Bandicam
By techmot in forum Capturing and VCRReplies: 3Last Post: 24th Feb 2023, 09:04 -
How to fix MP4 videos by command line running VLC player in Windows 10
By zydjohn in forum Video ConversionReplies: 7Last Post: 29th Nov 2021, 08:27 -
Which is better? Wirecast or OBS?
By Truthler in forum Video Streaming DownloadingReplies: 2Last Post: 30th Jul 2021, 15:11 -
Windows Media Player Stopped Playing MP3's
By cornemuse in forum Software PlayingReplies: 1Last Post: 17th Dec 2020, 11:55 -
one audio language option vanished, in a dual audio track IN VLC mdia plyr
By jraju in forum Newbie / General discussionsReplies: 0Last Post: 28th Dec 2019, 06:43
