Hello, thanks for the help in advance. I am trying to split videos in 1 second intervals. I am using the program batch video splitter. In my notes TEST1 splits perfectly in 1 second intervals. However in Test1 is splitting it out in the 10 second intervals instead of 1. I have used multiple video splitting programs, and I can only get to 10 seconds. Could anybody please help me convert the video to the correct format. Looking to convert my video to Test 2 Videos in the documents. Thanks
https://files.videohelp.com/u/303238/Test1.txt
https://files.videohelp.com/u/303238/Test2.txt
Results 1 to 10 of 10
The smallest timeframe that you can split while copying the video depends on where the keyframes are placed in the source video. eg. If they are placed at 10 seconds apart - 10 seconds is the miniumum timeframe that you can split without re-encoding. The reason is many frames are incomplete and use temporal compression - they rely on data from other frames, so you cannot cut where ever you want, unless all frames are IDR-frames (true keyframes)
You can test this in avidemux and navigate foward by keyframes (the ">>" button in the GUI, or up arrow key). If it jumps 10 seconds you have your answer - the problem is your video. You would have to re-encode to create smaller divisions (lose quality, unless you use a lossless codec, but that will increase the filesize by many times) -
One way to do it would be to re-encode with 1 sec keyframes, then use whatever batch video splitters you used earlier. Since you have 23.976p video, a max keyframe interval of 24 would be 1 second. You can set it smaller if you want higher precision cutting: eg. -g 12 would be half second for 23.976p video
You could use ffmpeg; in ffmpeg -g is the max keyframe interval. There are some ffmpeg GUI's but I'm not up to date on the various ffmpeg GUIs
Code:ffmpeg -i input.mp4 -c:v libx264 -ref 4 -crf 18 -g 24 -c:a copy output.mp4
Another way to do it in 1 step directly (in theory) would be to split and encode directly in ffmpeg using -f segment ; but I've never gotten it to work correctly
https://ffmpeg.org/ffmpeg-formats.html#segment_002c-stream_005fsegment_002c-ssegment -
It's a reference frame which is used to define future frames.
Google video reference frame,it will tell you more.
Ok. So as I now understand it, reference frames can be I frames or P frames. https://blog.video.ibm.com/streaming-video-tips/keyframes-interframe-video-compression/
The P frame can look back to an I frame or a P frame.
The B frame can look back or forward to an I frame or a P frame.
There is also this … https://en.wikipedia.org/wiki/Reference_frame_%28video%29
“ Some modern video encoding standards, such as H.264/AVC, allow the use of multiple reference frames. This allows the video encoder to choose among more than one previously decoded frame on which to base each macroblock in the next frame. While the best frame for this purpose is usually the previous frame, the extra reference frames can improve compression efficiency and/or video quality. Note that different reference frames can be chosen for different macroblocks in the same frame. The maximum number of concurrent reference frames supported by H.264 is 16. Different reference frames can be chosen for each 8x8 partition of a macroblock.”
Recommended default: -refs 6 … https://help.encoding.com/knowledge-base/article/advanced-configuration-options-for-th...4-video-codec/Last edited by JN-; 7th Oct 2023 at 18:36.
iPhone video conversion
By Jeikobu in forum Video ConversionReplies: 2Last Post: 11th Aug 2023, 23:41 -
Video conversion programs?
By QvidZ in forum Newbie / General discussionsReplies: 3Last Post: 2nd Jun 2023, 01:55 -
How to overlay image on video without conversion (keeping video quality) ?
By aaajan in forum EditingReplies: 14Last Post: 28th Jan 2021, 13:38 -
Video conversion
By BorisTM in forum Video ConversionReplies: 8Last Post: 20th Jan 2021, 05:21 -
Video conversion but no audio
By Daves00 in forum Video ConversionReplies: 3Last Post: 27th Feb 2019, 14:34
