OK it's possible Potplayer uses a compatibility mode to compile dx9 shaders on their dx11 renderer. In which case: no problem, just use dx9 shaders.
MPC-hc/be require dx11 shaders with mpc-vr dx11.
Results 31 to 38 of 38
On the subject of filmgrain shaders,
I should add that they also increase perceived sharpness without using using any sharpener (with the correct grain Strength). Grain doesn't make the picture crisp, but does provide a boost for sources that may not sharpen well.
You can find some dx9 filmgrain shaders here: https://github.com/butterw/bShaders/tree/master/FilmGrain_Noise
- bNoise.hlsl (fastest filmgrain shader, band-limited uniform noise).
- FilmGrain1.hlsl (port from mpv, truncated gaussian/binomial noise distribution)
I may update to include a more advanced blending mode which takes into account source luma (ex: less grain in bright areas, no grain on black).
Semi-random grayscale noise.hlsl (n=4) by janwillem32 would also be worth tracking down as it has the best gaussian noise distribution.
Grain shaders should be used after all sharpening is done (so probably post-resize).
When upscaling without extra sharpening it is beneficial to use grain shaders pre-resize for 2 reasons:
1) any upscaling will smooth the noise distribution for bnoise and FilmGrain1 (it becomes gaussian).
2) the grain is larger. Single pixel grain is a bit small at 1080p and above. -
I am already using that shader in post resize to hide any artifacts that the sharpening shaders which are in pre resize cause. I am watching 1080p movies. The grain strength is grain*= 0.205121822830526;
If I am a bit close to the screen then I can see the grains and they are obvious. I have to move back so I don't see the grains. What grain strength do you recommend that I use? -
I don't go above 0.10 with FilmGrain1, I typically use 0.05 or less.
EDIT: Grain will degrade Signal/Noise if you add too much.Last edited by butterw; 26th Nov 2023 at 14:12.
User parameters are defined at the top of the code with #define, you don't need to modify the code of the shader itself.
Code:#define INTENSITY 0.05 /* --- mpv FilmGrain v1 (dx9) --- */ /* v0.2 (2023-11) parameter INTENSITY noise intensity, ex: 0.05, typ: [0 to 0.10].
https://github.com/butterw/bShaders/blob/master/FilmGrain_Noise/grain.hlsl
It should allow for less intrusive filmgrain.
- You can apply less grain to dark and bright areas vs midtones with parameter Curve01, ex: 0.25, typ [0 to 1.0].
- It uses the gaussian noise pattern from "semi-random grayscale noise.hlsl".
- the Strength scale is modified, ex: Strength 16. -
I am currently using these shaders in pre-resize:
1) Sharpen.txt from https://drive.usercontent.google.com/download?id=1OunXPIZUkAJeXMFPIDFFlGFbqa9XK3V8
2) CAS-dx9.hlsl from https://gist.github.com/butterw/ceb89a68bc0aa3b0e317660fb4bacaa3
Also I am using these shaders in post-resize:
1) Contrast.10.hlsl from https://github.com/butterw/bShaders/blob/master/A-pack/Shaders/contrast.10.hlsl
2) Grain.hlsl from https://github.com/butterw/bShaders/blob/master/FilmGrain_Noise/grain.hlsl
I had to put the 2 sharpening shaders in pre because some videos got artifacts if I put them in post.
The videos look nice and colorful. Is what I am using ok?
Pixel-shaders for video playback (.hlsl, .glsl)
By butterw in forum Software PlayingReplies: 41Last Post: 2nd Apr 2024, 15:21 -
[A-Pack v1.50, Open-source] Video-player Adjustments shaders Pack.
By butterw in forum Latest Video NewsReplies: 2Last Post: 20th Nov 2023, 08:58 -
FREE motion interpolation solution (Uplavnyalka), pixel shaders
By DanilaZabiaka in forum Newbie / General discussionsReplies: 6Last Post: 18th Oct 2020, 09:54 -
PotPlayer crashing
By Rafael Dominiquini in forum Software PlayingReplies: 13Last Post: 18th May 2020, 21:40 -
PotPlayer replacement
By Dreamer in forum Software PlayingReplies: 9Last Post: 1st May 2020, 16:29
