Hey there,
I want to sync a bunch of mkv files with audio files from another source.
The problem is that I need to cut and shift the audio files at certain points of the video.
In particular after the intro of an episode and sometimes after a few seconds of black screen in the video.
So I'm looking for a (preferably free) program where I can visually see how to cut and sync the audio file, with no or little quality loss.
Video format: HEVC
Audio format: AC-3
Correct me if I'm wrong, but it seems avidemux is not the right tool for what I'm trying to do.
To be more specific, I don't want to change anything about the video file. I only want to change the audio file.
The first 2 min of the video and audio file are in sync. I then need to cut the audio file and give it about 2000ms delay. I have to do this a few times.
I then want to render only the audio file and multiplex it with mkvtoolnix. -
Let's assume you have
- movie a with hevc video and ac3 audio.
- audio b (ac3) from another source.
Then:
extract audio from a as ac3 file.
Load audio a and audio b in audacity and match the tracks from b to a.
Then delete audio a from audacity and save b.
Then mux the hevc video track from a with b. -
Thanks! That will work.
Although a little bit more tedious than I was hoping for.
Easiest way to automatically sync two tracks by waveform?
By shampistols69 in forum AudioReplies: 1Last Post: 20th Jul 2023, 22:54 -
Playing back PCM (44,100 kbps) audio tracks on blu-ray player = out of sync
By digitalfreaknyc in forum Software PlayingReplies: 19Last Post: 3rd May 2022, 00:48 -
Video editing program with multi audio tracks?
By cottage in forum Newbie / General discussionsReplies: 6Last Post: 8th Sep 2020, 14:52 -
How to extract/cut parts from a mkv including all audio and subtitle tracks
By Baldrick in forum User guidesReplies: 23Last Post: 22nd Mar 2019, 11:00 -
Program to cut M2TS file into clip with all tracks "un-touched"
By kpic in forum EditingReplies: 2Last Post: 12th Dec 2018, 13:20
