Results 1 to 11 of 11
  1. Hello. I am trying to render an ISO for a Blu-Ray project I have been working on in MAGIX DVD Architect Build 100.
    The error is "Warning: An Error occurred while writing a file. An invalid pointer was specified". I did some research and the fixes I found and tried were, running the program in administrator mode, saving the ISO to a different hard drive than where the project file lived, making sure chapter points were not to close to the end of the video files (which I really thought would do the trick), removing any potentially problematic video files (like AVIs that I lazily threw in rather than converting to a better format). None of it worked. I really can't imagine what the issue is. All the main video files after the pre-menu videos are proper .ts files that I used avidemux to make. They all load in fine and give me no warnings before it lets me prepare the ISO. The ISO gets about 40 - 50% through and then shoots that message at me. Does anyone know what this might be and what else I should try?
    If you need any more information, please let me know, thank you so much!
    canada
    Thread moved to the blu-ray authoring forum where you can get more help.
    Aug 2006
    If creating the Blu-ray files and folders don't cause any errors, you could create a Blu-ray ISO using Imgburn.
  4. Originally Posted by usually_quiet View Post
    How exactly would I do that? I can't transfer all that work over.
    Aug 2006
    Did DVD Architect create a BDMV folder and a CERTIFICATE folder for your Blu-ray? Those folders (including their contents) are what you need to add to ImgBurn to create the ISO.
  6. Originally Posted by usually_quiet View Post
    No, it did not.
    Aug 2006
    No, it did not.
    Can you try authoring the Blu-ray without creating an ISO? If that fails then the error occurs during the authoring process and is not specifically related to ISO creation.
  8. Originally Posted by usually_quiet View Post
    No, it did not.
    I will try that and get back, thank you.
  9. Originally Posted by usually_quiet View Post
    No, it did not.
    When I go to try and do that, like click the burn button, it still wants to create an iso to continue so it will give me the same error.
  10. Member Cornucopia's Avatar
    I suggest starting with just one or 2 assets, build an iso, delete it, add another asset, build, delete, add another etc until you find what is causing the problem. It may take quite a while, but you will at least be sure of the culprit (unless there is more than 1).
  11. Originally Posted by Cornucopia View Post
    Alright, thank you.
