Hi,
I have many videos (PVR from TV).
They have many different audio levels.
Most of those are same, others are lower other higher.
Is there a (free) program to check (in table view), all the video levels?
I want enhance the lower signals and diminish the higher levels.
Thanks.
P.S. I'm not looking for a program to modify audio levels (I use ShanaEncoder) but at a program to check a bunch of files!
Something like this. Ex:
Video1 db 82
Video2 db 82
Video3 db 54
Video4 db 82
Video5 db 96
Video6 db 82
Video7 db 61
Video8 db 82
It would be helpful if you posted what type of files you need information from (i.e. container type, audio codec used). Are all the files of the same type? I recommend that you attach an example file or a mediainfo report of an example file.
AACgain or BS FAG available from this site maybe able to do want want depending on the type of files you have.
Is there a forum to discuss TV/Monitors?
By timg11 in forum Off topicReplies: 3Last Post: 2nd Sep 2023, 15:18 -
VLC can't cope with two monitors
By bwallx in forum Newbie / General discussionsReplies: 5Last Post: 18th Mar 2023, 13:04 -
PotPlayer Window Not Maximizing Across 4 Monitors
By rae@sewaustin.com in forum Software PlayingReplies: 0Last Post: 21st Sep 2022, 12:40 -
Monitors for casual gamers
By Rostin in forum ComputerReplies: 0Last Post: 10th Mar 2020, 04:40 -
How to Expand PotPlayer to all monitors???
By potato502 in forum Software PlayingReplies: 3Last Post: 21st Jul 2019, 13:02
