Try StreamFab Downloader and download streaming video from Youtube, Netflix, Amazon! Download free trial.
  1. In NVEnc section there's only h264 and h265 codec support, will Hybrid get NVEnc AV1 support in future?
  2. Hybrid supports NVEnc AV1 for a while now.
    Hybrid runs 'NVEncC --check-features' to check what the used GPU supports and accordingly adjusts the settings.
    => What do you get if you run:
    "PATH to Hybrid\64bit\NVEncC.exe" --check-features
    in a Windows terminal?
    Cu Selur
    users currently on my ignore list: deadrats, Stears555
