Ok recently i have been trying to convert DivX to SVCD... I had succesfully made an NTSC SVCD using the foolproof guide. Now i tried to do the same thing as i had done with the the first movie... but this one was 25 fps so i decided to just make it PAL SVCD compliant. Now everything encoded fine... 2 pass VBR with 300 min and 2520 max. Now when i try to multiplex and cut with bbmpeg and the end of the proccess i get an error saying it can't open the .mpg it just created. So what i end up with is an 813 mb mpg that should be over a gig if it's not cut... so it is cut but it doesn't start to make the other half of the movie... I have been messing around with it for 2 days now with no luck....
SVCD specs are as follows
Video: 2 pass VBR 300 min - 2520 max
480:576 resolution
25 fps
Audio: 224 kbits mpeg2
I hope someone has some solutions...... If you need more info just ask...
Thanks in advance
DGf
Results 1 to 1 of 1
The Film Machine Problem... MULTIPLEXING FREEZE
By supermannnnn in forum Video ConversionReplies: 3Last Post: 16th Dec 2012, 11:51 -
Cutting MTS: splitter problem
By cheerful in forum EditingReplies: 3Last Post: 6th Jun 2012, 19:26 -
.264 + AC3 Multiplexing problem
By 557953 in forum EditingReplies: 4Last Post: 24th May 2011, 09:16 -
subtitle problem after cutting commercial from video
By satish_j in forum SubtitleReplies: 4Last Post: 25th Nov 2010, 00:51 -
Little problem-Cutting Scenes-Ideas?
By n3ur0 in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2010, 08:44
