    Aug 2023
    Turkey
    i try to write one python code thad i can get header
    bud not get the same as in chrome
    any one know how to get the right header with python ?
    here my code ....
    import requests
    url = "https://licanse.sever.com"
    response = requests.get(url)
    headers = response.headers
    with open("header.py", "w") as file:
        file.write("headers = {\n")
        for key, value in headers.items():
            file.write(f'    "{key}": "{value}",\n')
        file.write("}\n")
    print("Header to 'header.py' saved.")
    ps : the url its just example
    Feb 2022
    Search the forum first!
    import requests
    from rich.console import Console
    console = Console()
    url = "https://cwip-shaka-proxy.appspot.com/no_auth"
    response = requests.options(url)
     # this will allow you to see what the response is and understand the data format.
    console.print(headers)
    # and you can contruct headers from this data
    # says call to the license server should be by POST
    # no Origin needed in fact this site doesn't need any request headers
    # to get the data to constuct your headers.py
    cont = headers['Content-Type']
    xcloud = headers['X-Cloud-Trace-Context']
     # etc
    # and put together to produce a reasonable headers file
    # instead of printing you can save to a variable ready to write to file
    print( f"'Content-Type':'{cont}',\n'X-Cloud-Trace-Context':'{xcloud}',")   # just two items as example only
    Remember if you call the license server asking for headers all you will get is response headers - not request headers. So above we ask for options before-hand. The options response tell us what the request headers should contain. And you can make a good attempt at constructing headers well enough to pass scrutiny. In practice it is ail very much standard and you will only likely need to extract tokens or x-authority values by this method and add those to a standard file
    Noob Starter Pack. Just download any Widevine media! Over 30,000 downloads for V6!.
    Aug 2023
    Turkey
    big thanks for you tips and example
    will try again
    bud realy not easy to understand bud will try my best
    if i succes i will share the file sure .. it will be very easy to get header and implent in the l3.py
    i will share what i begin and make samething bud not done with header section
    if you want you can chack this
    and mybe can anybudy help me to finish this
    you have 2 option
    1. use with mpd link get the pssh over kid and give the lisance url and
    (futher = creat correckt header from lisance server thad i wold found out how )
    and calculate you kid key
    2. all the same with manuel pssh .
    import base64
    import requests
    import xml.etree.ElementTree as ET
    from pywidevine.L3.cdm import cdm, deviceconfig
    from base64 import b64encode
    from pywidevine.L3.getPSSH import get_pssh
    from pywidevine.L3.decrypt.wvdecryptcustom import WvDecrypt
    def get_pssh_from_url(url):
        if response.status_code == 200:
            xml_data = response.text
            root = ET.fromstring(xml_data)
            namespace = {'xmlns': 'urn:mpeg:dash:schema:mpd:2011', 'cenc': 'urn:mpeg:cenc:2013'}
            kid_element = root.find(".//xmlns:ContentProtection[@cenc:default_KID]", namespaces=namespace)
            if kid_element is not None:
                kid_value = kid_element.get("{urn:mpeg:cenc:2013}default_KID")
                formatted_kid = '-'.join([kid_value[i:i+8] for i in range(0, len(kid_value), 8)])
                def get_pssh(keyId):
                    array_of_bytes = bytearray(b'\x00\x00\x002pssh\x00\x00\x00\x00')
                    array_of_bytes.extend(bytes.fromhex("edef8ba979d64acea3c827dcd51d21ed"))
                    array_of_bytes.extend(b'\x00\x00\x00\x12\x12\x10')
                    array_of_bytes.extend(bytes.fromhex(keyId.replace("-", "")))
                    return base64.b64encode(bytes.fromhex(array_of_bytes.hex()))
                pssh = get_pssh(kid_value)
                print(f"KID: {formatted_kid}\n")
                print(f"PSSH: {pssh.decode('utf-8')}")
                return pssh
            else:
                print("KID bulunamadı.")
        else:
            print(f"URL'ye erişilemedi. Hata kodu: {response.status_code}")
        return None
    def write_headers_to_file(response):
            file.write("}\n")
        print("Header bilgileri 'header.py' dosyasına kaydedildi.")
    def get_license_url():
        url = input('License URL: ')
        return url
    def perform_decryption(pssh, lic_url):
        wvdecrypt = WvDecrypt(init_data_b64=pssh, cert_data_b64=b'', device=deviceconfig.device_android_generic)
        widevine_license = requests.post(url=lic_url, data=wvdecrypt.get_challenge())
        if not widevine_license.ok:
            print("License isteği başarısız: \n", widevine_license.content)
            return False, []
        license_b64 = b64encode(widevine_license.content)
        wvdecrypt.update_license(license_b64)
        Correct, keys = wvdecrypt.start_process()
        if Correct:
            with open("output.txt", "a") as output_file:
                output_file.write('\n')
                output_file.write(f"PSSH: {pssh}\n")
                output_file.write("License URL: " + lic_url + '\n')
                for key in keys:
                    output_file.write('--key ' + key + '\n')
            print("Çıktı başarıyla 'output.txt' dosyasına eklenmiştir.")
            return True, keys
        else:
            print("Decrypt işlemi başarısız.")
            return False, []
    def get_manual_pssh():
        pssh = input('Manual PSSH Input: ')
        return pssh
        if Correct:
                for key in keys:
            return True, keys
        else:
            return False, []
    while True:
        choice = input("Press For MPD URL: (1)   Manual PSSH Input: (2)   Exit: (0): ")
        if choice == '0':
            break
        elif choice != '1' and choice != '2':
            print("Geçersiz seçenek.")
            continue
        if choice == '1':
            mpd_url = input("MPD URL: ")
            pssh = get_pssh_from_url(mpd_url)
        elif choice == '2':
            pssh = get_manual_pssh()  # Prompt for manual PSSH input
        if pssh is None:
            print("PSSH alınamadı.")
            continue
        lic_url = get_license_url()
        success, keys = perform_decryption(pssh, lic_url)
        if success:
            print("Decrypt işlemi başarılı.")
            for key in keys:
                print("--key", key)
        else:
    Aug 2023
    Turkey
    Originally Posted by A_n_g_e_l_a View Post
    import requests
    console = Console()
     # etc
    I had time to examine more, but there is such a situation.
    example
    The data we receive from Chrome and the data we receive from here do not match and it seems to bring wrong information, for example.
    chrome
    headers = {
        'authority': 'prod.spark.ziggogo.tv',
        'accept': '*/*',
        'accept-language': 'tr-TR,tr;q=0.9',
        # 'cookie': 'OptanonAlertBoxClosed=2023-09-26T16:41:27.075Z; rxVisitor=16957464766279HHLCUB8N0KGPKPEAFUJUN4P25N4SKEF; dtCookie=v_4_srv_35_sn_C36448F1C917DD4634525D8A1249F3F5_app-3A9bed77b55cacea1c_1_ol_0_perc_100000_mul_1; dtSa=-; OptanonConsent=isGpcEnabled=0&datestamp=Tue+Sep+26+2023+21%3A39%3A38+GMT%2B0300+(GMT%2B03%3A00)&version=202306.2.0&browserGpcFlag=0&isIABGlobal=false&hosts=&consentId=a16bbc10-04dc-48f9-b7df-979cb2423feb&interactionCount=1&landingPath=NotLandingPage&groups=C0001%3A1%2CC0002%3A1%2CC0003%3A1&geolocation=%3B&AwaitingReconsent=false; ACCESSTOKEN=eyJ0eXAiOiJKV1QiLCJraWQiOiJvZXNwX3Rva2VuX3Byb2RfMjAyMDA4MTkiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJ3ZWItYXBpLXByb2Qtb2JvLmhvcml6b24udHYiLCJzaWQiOiI2M2RkMWRlZWRjOGVjZGUyOTc2YzM3OGEzNTZjMjczMzYzNjg2NzA4YjI5MGJmMDQ4NWYwMzBiYTc5NGFhMjk3IiwiaWF0IjoxNjk1NzUzNTc4LCJleHAiOjE2OTU3NjA3NzgsInN1YiI6IjE4NjQyOTc0X25sIn0.Gx7vJxXE5yYlTAKVgncyd4r6wlrgZfKrX_YPgOeUjz8; CLAIMSTOKEN=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJkZXZpY2VzIjpbXSwiY3VzdG9tZXJJZCI6IjE4NjQyOTc0X25sIiwicHJvZmlsZXMiOlsiMDA2MGU1YjUtMzM2My00NzFjLWE4MWMtODE5YTgzYWI5OGE5Il0sImV4cCI6MTY5NTgzOTk3OH0.uARL9tPG4c1IEdZXI5h6fCEMqJp7-4g8jeStSbsDFdM; rxvt=1695755396912|1695753577156; dtPC=35$153577154_920h-vCMPIQUUJREAIRUGDTOHLRKRWEUBRUGCL-0e0',
        'devicename': 'Google%20Chrome',
        'origin': 'https://www.ziggogo.tv',
        'referer': 'https://www.ziggogo.tv/',
        'sec-ch-ua': '"Google Chrome";v="117", "Not;A=Brand";v="8", "Chromium";v="117"',
        'sec-ch-ua-mobile': '?0',
        'sec-ch-ua-platform': '"Windows"',
        'sec-fetch-dest': 'empty',
        'sec-fetch-mode': 'cors',
        'sec-fetch-site': 'same-site',
        'user-agent': 'Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/117.0.0.0 Safari/537.36',
        'x-cus': '18642974_nl',
        'x-drm-schemeid': 'edef8ba9-79d6-4ace-a3c8-27dcd51d21ed',
        'x-go-dev': '0e6a7a87-aa06-4ee7-9bb6-9c53dccf8305',
        'x-oesp-username': 'kontak4@hotmail.com',
        'x-profile': '0060e5b5-3363-471c-a81c-819a83ab98a9',
        'x-streaming-token': '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',
        'x-tracking-id': '5242f1b071c6b4c053ee8cb4a0c36a9aad8dc3e121c905e3b69ccb634464ca66',
        'content-type': 'application/x-www-form-urlencoded',
    python code get header
    headers = {
        "Content-Type": "application/json",
        "Content-Length": "141",
        "Server-Timing": "dtRpid;desc="-1964344660", dtSInfo;desc="0"",
        "X-OneAgent-JS-Injection": "true",
        "x-request-id": "cd41f6f63c052c8e04c3bac480b2ab2b",
        "X-Content-Type-Options": "nosniff",
        "Access-Control-Allow-Credentials": "true",
        "Access-Control-Allow-Methods": "GET, POST, PUT, OPTIONS, DELETE, HEAD, PATCH",
        "Access-Control-Allow-Headers": "Accept-Charset, Accept-Encoding, Access-Control-Request-Headers, Access-Control-Request-Method, Authorization, Cache-Control, Connection, Content-Encoding, Content-Type, Content-Length, Cookie, DNT, Date, Host, If-Modified-Since, Keep-Alive, Origin, Referer, Server, TokenIssueTime, Transfer-Encoding, User-Agent, Vary, X-CustomHeader, X-Requested-With, password, username, x-request-id, x-ratelimit-app, x-guest-token, X-HTTP-Method-Override, x-oesp-username, x-oesp-token, x-cus, x-dev, X-Client-Id, X-Device-Code, X-Language-Code, UserRole, x-session-id, x-entitlements-token, x-go-dev, x-profile, x-api-key, nv-authorizations, X-Viewer-Id, x-oesp-profile-id, x-streaming-token, x-streaming-token-refresh-interval, x-drm-device-id, x-profile-id, x-ui-language, deviceName, x-drm-schemeId, x-refresh-token, X-Username, Location, x-tracking-id",
        "Access-Control-Expose-Headers": "x-streaming-token, x-streaming-token-refresh-interval, x-drm-device-id, x-profile-id, x-ui-language, deviceName, x-drm-schemeId, nv-qm-signature, nv-qm-version, x-refresh-token, Location",
        "Access-Control-Max-Age": "1728000",
        "X-EdgeConnect-MidMile-RTT": "5",
        "X-EdgeConnect-Origin-MEX-Latency": "11",
        "Date": "Tue, 26 Sep 2023 18:50:52 GMT",
        "Connection": "keep-alive",
        "Set-Cookie": "dtCookie=v_4_srv_31_sn_E41B342C05FBCE6AFADCA0ADB50C3D33_perc_100000_ol_0_mul_1_app-3Aea7c4b59f27d43eb_1; Path=/; Domain=.horizon.tv",
        "Access-Control-Allow-Origin": "https://www.horizon.tv",
