Hi, I have an avi file that locks up at about 46 mins of the total 59mins. When watching you can fast forward past this point and it will continue on but when encoding with tmpgenc it stops and can't finish encoding the file. It stops at 77% and that part won't even play. I beleive that I don't have the full TMPGEnc 2.53 version. I have the Mpeg Encoder of TMPGEnc but the wizard that you show in your example of how to encode specified sections of the avi file doesn't open up when I start and I don't have that option under the file tab. I want to encode this file in two parts then join the MPEGS together. Can you show me how to do this maybe with Mpeg tools or something.
Lakeida
It sounds like you have some bad frames.
They can be scanned and identified in Virtualdub where you can then remove the bad frames.
TMPGE encoding should be ok now....encode it as a whole, then...If you still want 2 parts go to TMPGE>File>MPEG Tools>Merge and Cut.
Then you can set it for Mpeg1 or 2 or whatever you want it to be and split it in 2. (if you want to split it in its AVI format use AviChop)
Make a playable file from AVI part 5 when you don't have parts 1-4?
By gumbygum in forum Software PlayingReplies: 3Last Post: 12th Aug 2011, 08:51 -
Windows Movie Maker: AVI's sound bad, MPEGs won't play
By Canopus Smoker in forum Newbie / General discussionsReplies: 3Last Post: 26th Nov 2008, 10:54 -
Is there a mac program that join parts of a video file in rar pieces?
By VidHunter in forum MacReplies: 5Last Post: 22nd Mar 2008, 07:58 -
Simple yet good... that can join my 2 parts avi video into 1
By mai_hnf in forum EditingReplies: 6Last Post: 8th Sep 2007, 02:59 -
Breaking down a VOB file into its component parts
By djdust in forum Newbie / General discussionsReplies: 3Last Post: 5th Sep 2007, 21:06
