Post the preview screenshot for this
Code:MP_Pipeline(""" ### platform: win64 BlankClip() ### ### ### platform: win32 version() ### ### ### platform: win64 ### ### """)
and this
Code:MP_Pipeline(""" ### platform: win64 version() ### ### ### platform: win32 ### ### ### platform: win64 ### ### """)
Results 61 to 75 of 75
mp_pipeline is not working at all for you
Are you running as administrator or have elevated privileges ? mp_pipeline has a slave executable (.exe) that windows might not like, especially if it's run from a C:\ drive
What about a simple avs script , without mp_pipeline, to verify that avs x86 and x64 are working
you would check with avspmod x64 to initialize avs x64
And a simple x86 avs script - you would check with avspmod x86 to initialize avs x86Code:version()
Code:version()
Sorry, but I don't understand, my friend. Is there another filter besides ''restorefps'' that can do this job in the 64-bit version?
I really liked the smoothness you left in the file, but I can't process the video at all.
If I sent you the files, could you do just this ''restorefps'' phase for me and I could reprocess it later with my filters in the 64-bit version? -
Not that I know of
If you can't get mp_pipeline working, a workaround is you can run restorefps in 32bit avisynth (e.g. vdub x86) , export a lossless intermediate . Import that lossless intermediate into 64bit avisynth for farther processing
The benefit of the mp_pipeline workflow is fewer steps, less HDD space, and faster overall -
Use a 32bit bit application, like 32bit avspmod or 32bit vdub2 . If you use avspmod, you will eventually have to encode it with avspmod, and it's not easy setting up the encoders for x86 . You can use 32bit avspmod to preview, but I would use vdub2 32bit to encode to a lossless intermediate like lagarith or ut video
Because I tried to do the ''restorefps'' processing in AvsPmod_32 and I got this error.
It means you have KNLMeansCL.dll in the wrong directory. That is a 64bit plugin, but you placed it in the 32bit plugins directory . Move it somewhere else , and all the 64bit plugins to the correct place, or somewhere else .
In your script you will need a source filter as well, before restorefps. You have to load the video -
If you open an AviSynth scropt with a 64 application you will get 64 AviSynth. If you open an AviSynth script with a 32 bit application you will get 32 bit AviSynth.
The error message is telling you that you are running 32 bit AviSynth and tried to load a 64 bit AviSynth filter (knlmeanscl). 32 bit AviSynth can only use 32 bit filters, 64 bit AviSynth can only use 64 bit filters. So you need to replace that 64 bit filter with a 32 bit version.
Finally, even if you successfully loaded the filter your script wouldn't run because you never opened a video file in the script. -
Good afternoon, friend,
I managed to advance to this stage of rife(), but it gives me this GPU error. Could it be because the processing needs to be done only by the GPU or can I do it through the processor?
Taking advantage of the question, where can I download the DLL for the ''avssr64'' filter? I couldn't find it on any website. -
avs version of RIFE is based on the vulkan/NCNN version and is GPU only , but many GPU's are supported, even integrated GPU's
Make sure you fulfill the requirements listed in the requirements section
https://github.com/Asd-g/AviSynthPlus-RIFE
Requirements:
Vulkan device
AviSynth+ r3688 or later (1 / 2 / 3)
Microsoft VisualC++ Redistributable Package 2022 (can be downloaded from here)
You might need to update GPU drivers . If you download gpu-z, there will be a checkbox for vulkan. If it's checked, it means your GPU supports vulkan and should work .
There are other framerate interpolators you can use instead of rife - such as mvtools2, svpflow, interframe (uses mvtools2) but generally they are not as good, but much faster
https://www.infognition.com/super_resolution_avisynth/Taking advantage of the question, where can I download the DLL for the ''avssr64'' filter? I couldn't find it on any website. -
How do i upscale PAL
By HansensUniverse in forum Newbie / General discussionsReplies: 26Last Post: 4th Feb 2022, 00:30 -
How do you upscale videos in MeGUI?
By Guernsey in forum Newbie / General discussionsReplies: 9Last Post: 5th Jan 2022, 14:09 -
AVISynth Help: How do I upscale in MeGUI?
By Guernsey in forum Newbie / General discussionsReplies: 0Last Post: 12th Oct 2021, 04:45 -
What is a better method to upscale 3D images?
By Guernsey in forum Newbie / General discussionsReplies: 14Last Post: 2nd Oct 2021, 13:54 -
What is the best way to upscale videos.
By Felow in forum Video ConversionReplies: 15Last Post: 9th Jan 2020, 15:00
