Hi
#--> a cat here. However
Please download thanks
https://www.swisstransfer.com/d/f3a8d0de-644f-4ede-af4e-274bf6e777c2
In the package above I have 3 mxf files (file1.mxf file2.mxf file3.mxf)
and ffmpeg.exe
and ffmbc.exe
My target is to concatenate the 3 .mxf files into one so that the concatenated output is playable in Sony PDW-HD1500 deck, Sony PDW-700/F800 or Sony PDW-U1/U2 disc unit
maybe if you don't have one of this 3 sony deck is not possibile or it's difficult to test this thing. However
if I do:
the out.mxf file is not playable in Sony deckCode:ffmpeg -y -f concat -safe 0 -i concatList.txt -c:v copy -c:a copy out.mxf
Consider that the single .mxf files are fully playable in Sony decks, but the problem is that I cannot find a way that concatenate the 3 files
FFMBC encode right in .mxf but I cannot find an option that concatenate multiple files
for example:
generate a outFFMBC.mxf that works and is playable on the decks but this is not the concatenate of the 3 .mxf filesCode:ffmbc -y -i file1.mxf -vcodec copy -acodec copy -target xdcamhd422 outFFMBC.mxf -acodec pcm_s24le -ar 48000 -newaudio
and for example using ffmpeg:
outIncompatible.mxf is similar to the ffmbc 'one but don't works in the decksCode:ffmpeg -y -i file1.mxf -i file1.mxf -map 0:0 -map 1:a -pix_fmt yuv422p -vcodec mpeg2video -flags +ildct+ilme -top 1 -vtag xd5c -b:v 50000k -minrate 50000k -maxrate 50000k -acodec pcm_s24le -ar 48000 -f mxf outIncompatible.mxf
Is there a way to encode right using ffmpeg or another way that create .mxf concatenated files that are compatilble with the Sony decks? thanks
maybe think "solved" using ffmpeg to concatenate, and ffmbc to remux
Code:ffmpeg64BitJuly2017.exe -y -threads auto -f concat -safe 0 -i AllRemuxConcatList.txt -map 0:? -ignore_unknown -vcodec copy -acodec copy "%cd%\TEMPoutputRoutine_1_solo_MXF.mxf" ffmbcX642017.exe -y -i "%cd%\TEMPoutputRoutine_1_solo_MXF.mxf" -vcodec copy -acodec copy -target xdcamhd422 "%cd%\outputRoutine_1_solo_MXF.mxf" -acodec pcm_s24le -ar 48000 -newaudio -acodec pcm_s24le -ar 48000 -newaudio -acodec pcm_s24le -ar 48000 -newaudio
MVKmerge/FFMPEG Command Line to Copy Subtitles but in disabled mode?
By kwanbis in forum Video ConversionReplies: 0Last Post: 23rd May 2023, 11:29 -
How to merge DASH segmented STPP subtitles from an encrypted stream?
By user1020 in forum Video Streaming DownloadingReplies: 0Last Post: 21st May 2023, 14:04 -
Loosing Overall Bitrate in Direct Copy Mode both in Virtualdub and Avidemux
By DBCOOPER1990 in forum EditingReplies: 1Last Post: 16th Mar 2023, 05:45 -
Stream Copy or Direct Stream Copy?
By Guernsey in forum Newbie / General discussionsReplies: 0Last Post: 27th Aug 2021, 21:03 -
MXF IBBP To MXF I frame only
By zahoor in forum Video ConversionReplies: 3Last Post: 27th Feb 2021, 13:54
