  1. IS THERE A STEP BY STEP WAY TO RIP THE DVD MOVIE ON THE COMPUTER INTO CDR'S TO INLCUDE SOUND AND TESTING BEFORE COPING TO THE CD TO SEE INTO MY COMPUTER.
  2. go to the DVD RIP secton to the left menus on this site and look for the Sefy guides. It will get you started. to test, just use cd/rw's and you can re-format them if you make a mistake or the results are not to your liking.
  3. I NEED HELP GETTING SOUND ON MY BURNING. I GET THE PIC RIGHT BUT I GET NO SOUND AFTER. WHAT CAN I DO.
    Feb 2001
    Berlin, Germany
    Turn off the caps lock, read the ReadMe on a program, read the guides.
    If you still have problems, tell us which tools / guides you have used.
