Using:
I assumed ffmpeg would adjust at least the container fps to 50fps, but I get:Code:ffmpeg -y -r 50/1 -i "G:\TestClips&Co\files\ProRes\ProRes4444.mov" -c copy -r 50/1 -map 0:0 -map 0:1 -f mov "G:\Output\passthrough.mov"
I'm pretty sure this did work a few years ago, but I can't find anything that indicates how to do this with ffmpeg otherwise (no reencoding) or why it's not working.Code:General Count : 347 Count of stream of this kind : 1 Kind of stream : General Kind of stream : General Stream identifier : 0 Count of video streams : 1 Count of audio streams : 1 OtherCount : 1 Video_Format_List : ProRes Video_Format_WithHint_List : ProRes Codecs Video : ProRes Video_Language_List : English Audio_Format_List : PCM Audio_Format_WithHint_List : PCM Audio codecs : PCM Audio_Language_List : English Other_Format_List : QuickTime TC Other_Format_WithHint_List : QuickTime TC Other_Codec_List : QuickTime TC Other_Language_List : English Complete name : g:\Output\passthrough.mov Folder name : g:\Output File name extension : passthrough.mov File name : passthrough File extension : mov Format : MPEG-4 Format : MPEG-4 Format/Extensions usually used : braw mov mp4 m4v m4a m4b m4p m4r 3ga 3gpa 3gpp 3gp 3gpp2 3g2 k3g jpm jpx mqv ismv isma ismt f4a f4b f4v Commercial name : MPEG-4 Format profile : QuickTime Internet media type : video/mp4 Codec ID : qt Codec ID : qt 0000.02 (qt ) Codec ID/Url : http://www.apple.com/quicktime/download/standalone.html CodecID_Version : 0000.02 CodecID_Compatible : qt File size : 165697699 File size : 158 MiB File size : 158 MiB File size : 158 MiB File size : 158 MiB File size : 158.0 MiB Duration : 5005 Duration : 5 s 5 ms Duration : 5 s 5 ms Duration : 5 s 5 ms Duration : 00:00:05.005 Duration : 00:00:05:00 Duration : 00:00:05.005 (00:00:05:00) Overall bit rate mode : VBR Overall bit rate mode : Variable Overall bit rate : 264851467 Overall bit rate : 265 Mb/s Frame rate : 23.976 Frame rate : 23.976 FPS Frame count : 120 Stream size : 3795 Stream size : 3.71 KiB (0%) Stream size : 4 KiB Stream size : 3.7 KiB Stream size : 3.71 KiB Stream size : 3.706 KiB Stream size : 3.71 KiB (0%) Proportion of this stream : 0.00002 HeaderSize : 28 DataSize : 165693916 FooterSize : 3755 IsStreamable : No File creation date : 2023-09-21 15:36:29.900 UTC File creation date (local) : 2023-09-21 17:36:29.900 File last modification date : 2023-09-21 15:39:25.812 UTC File last modification date (local) : 2023-09-21 17:39:25.812 Writing application : Lavf60.10.100 Writing application : Lavf60.10.100 Video Count : 381 Count of stream of this kind : 1 Kind of stream : Video Kind of stream : Video Stream identifier : 0 StreamOrder : 0 ID : 1 ID : 1 Format : ProRes Format : ProRes Commercial name : ProRes Format version : Version 1 Format profile : 4444 Codec ID : ap4h Codec ID/Url : http://www.apple.com/quicktime/download/standalone.html Duration : 5005 Duration : 5 s 5 ms Duration : 5 s 5 ms Duration : 5 s 5 ms Duration : 00:00:05.005 Duration : 00:00:05:00 Duration : 00:00:05.005 (00:00:05:00) Bit rate mode : VBR Bit rate mode : Variable Bit rate : 263309138 Bit rate : 263 Mb/s Width : 1920 Width : 1 920 pixels Height : 1080 Height : 1 080 pixels Sampled_Width : 1920 Sampled_Height : 1080 Pixel aspect ratio : 1.000 Display aspect ratio : 1.778 Display aspect ratio : 16:9 Rotation : 0.000 Frame rate mode : VFR Frame rate mode : Variable Frame rate : 23.976 Frame rate : 23.976 (24000/1001) FPS FrameRate_Num : 24000 FrameRate_Den : 1001 Minimum frame rate : 23.970 Minimum frame rate : 23.970 FPS Maximum frame rate : 24.015 Maximum frame rate : 24.015 FPS Frame count : 120 Color space : YUVA Chroma subsampling : 4:4:4 Chroma subsampling : 4:4:4 Scan type : Progressive Scan type : Progressive Bits/(Pixel*Frame) : 5.296 Delay : 0 Delay : 00:00:00.000 Delay : 00:00:00:00 Delay : 00:00:00.000 (00:00:00:00) Delay_Settings : DropFrame=No / 24HourMax=No / IsVisual=No Delay_DropFrame : No Delay, origin : Container Delay, origin : Container Stream size : 164732944 Stream size : 157 MiB (99%) Stream size : 157 MiB Stream size : 157 MiB Stream size : 157 MiB Stream size : 157.1 MiB Stream size : 157 MiB (99%) Proportion of this stream : 0.99418 Writing library : Apple Writing library : Apple Language : en Language : English Language : English Language : en Language : eng Language : en colour_description_present : Yes colour_description_present_Source : Container / Stream Color primaries : BT.709 colour_primaries_Source : Container / Stream Transfer characteristics : BT.709 transfer_characteristics_Source : Container / Stream Matrix coefficients : BT.709 matrix_coefficients_Source : Container / Stream Audio Count : 285 Count of stream of this kind : 1 Kind of stream : Audio Kind of stream : Audio Stream identifier : 0 StreamOrder : 1 ID : 2 ID : 2 Format : PCM Format : PCM Commercial name : PCM Format settings : Little / Signed Format settings, Endianness : Little Format settings, Sign : Signed Codec ID : sowt Codec ID/Url : http://www.apple.com/quicktime/download/standalone.html Duration : 5005 Duration : 5 s 5 ms Duration : 5 s 5 ms Duration : 5 s 5 ms Duration : 00:00:05.005 Duration : 00:00:05.005 Bit rate mode : CBR Bit rate mode : Constant Bit rate : 1536000 Bit rate : 1 536 kb/s Channel(s) : 2 Channel(s) : 2 channels Channel positions : Front: L R Channel layout : L R Sampling rate : 48000 Sampling rate : 48.0 kHz Samples count : 240240 Bit depth : 16 Bit depth : 16 bits Delay : 0 Delay : 00:00:00.000 Delay : 00:00:00.000 Delay_DropFrame : No Delay, origin : Container Delay, origin : Container Delay relative to video : 0 Delay relative to video : 00:00:00.000 Delay relative to video : 00:00:00.000 Stream size : 960960 Stream size : 938 KiB (1%) Stream size : 938 KiB Stream size : 938 KiB Stream size : 938 KiB Stream size : 938.4 KiB Stream size : 938 KiB (1%) Proportion of this stream : 0.00580 Language : en Language : English Language : English Language : en Language : eng Language : en Default : Yes Default : Yes Alternate group : 1 Alternate group : 1 Other Count : 191 Count of stream of this kind : 1 Kind of stream : Other Kind of stream : Other Stream identifier : 0 StreamOrder : 2 ID : 3 ID : 3 Type : Time code Format : QuickTime TC Format : QuickTime TC Commercial name : QuickTime TC Duration : 5005 Duration : 5 s 5 ms Duration : 5 s 5 ms Duration : 5 s 5 ms Duration : 00:00:05.005 Duration : 00:00:05:00 Duration : 00:00:05.005 (00:00:05:00) Frame rate : 23.970 Frame rate : 23.970 FPS Frame count : 120 Time code of first frame : 00:00:00:00 Time code of last frame : 00:00:04:23 TimeCode_DropFrame : No Time code, stripped : Yes Time code, stripped : Yes Language : en Language : English Language : English Language : en Language : eng Language : en Default : No Default : No
I guess this should be easy and some ffmpeg user can help.
Cu Selur
Never have managed to get this to work in ffmpeg. The generally excepted method was to demux, and then remux at the new framerate. This works, but causes issues with timestamps. Whilst the output plays in MPC-HC, and VLC. I could never import into Avidemux without the timestamps being repaired first, which required re-encoding to save.
I now change the framerate in tsMuxer. Outputting to .m2ts, I then change the container to suit in Avidemux, or ffmpeg.
The above only affects the video stream. Audio remains unchanged.
Remux 29.97p fps to 23.976p fps WITHOUT re-encoding
By kalemvar1 in forum Video ConversionReplies: 6Last Post: 19th Jun 2022, 08:26 -
[FFMPEG BATCH SCRIPT] Remux MP4 to MKV removing all details data!
By Cauptain in forum Video ConversionReplies: 3Last Post: 12th Aug 2021, 03:38 -
Can't get FFMPEG Script to Remux to MP4 with Wav, It instead remuxes to MKV
By VideoFanatic in forum Video ConversionReplies: 3Last Post: 1st Aug 2021, 02:32 -
Can't seem to remux .TS files with ffmpeg
By CursedLemon in forum Video ConversionReplies: 4Last Post: 6th Oct 2019, 22:58 -
Change DTS-MA 7.1 Length (FPS)
By luciofulci in forum AudioReplies: 11Last Post: 6th May 2019, 03:15
