I have installed Hybrid
No matter what I do, it exports an avi files that are no playable at size 13.8-16kb.
If I choose mkv it works.
What am I doing wrong?
I used the simple x264 de-interlace job from this thread:
https://forum.videohelp.com/threads/401770-Quick-simple-guide-to-QTGMC-deinterlacing-%...for-newbies%29
Creating job for current source
-> Creating jobs for source: (1)
-> Generating calls for: C:\Users\Idan\Desktop\פסח 7-4-2001.avi
Enforcing cfr decoder output due to avi output.
adding x264 calls for source: 1
createJobs for C:\Users\Idan\Desktop\פסח 7-4-2001.avi
creating audio subjobs,...
creating attachment extraction subjobs
creating video subjobs
creating muxing subjobs
Adding additional muxing calls, since ffmpeg can't handle raw H.264 video properly.
optimizing the subJobs
-> finished creating subjobs for current source
added new job with id 2023-09-20@17_45_38_3410
starting 2023-09-20@17_45_38_3410_01_audio@17:45:38.358 - C:\Users\Idan\Desktop\פסח 7-4-2001.avi
finished after 00:00:00.386
starting 2023-09-20@17_45_38_3410_02_video@17:45:38.747 - C:\Users\Idan\Desktop\פסח 7-4-2001.avi
finished after 00:01:01.624
starting 2023-09-20@17_45_38_3410_03_muxing@17:46:40.374 - C:\Users\Idan\Desktop\פסח 7-4-2001.avi
finished after 00:00:10.573
delete C:\Users\Idan\AppData\Local\Temp\2023-09-20@17_45_38_3410_02.264
starting 2023-09-20@17_45_38_3410_05_muxing@17:46:51.072 - C:\Users\Idan\Desktop\פסח 7-4-2001.avi
finished after 00:00:00.113
delete C:\Users\Idan\AppData\Local\Temp\2023-09-20@17_45_38_3410_02.mkv
delete C:\Users\Idan\AppData\Local\Temp\iId_2_aid_1_2023-09-20@17_45_38_3410_01.wav
Job 2023-09-20@17_45_38_3410 finished!
Got it sorted using a different Video processing like UT Video.
What is the best option to keep the file lossless? -
Depends on your needs. Some lossless formats are easier to decode than others.
Regarding your problem:
a. Would need a debug output to know what happened.
b. It's a bad idea to put AVC and other complex video formats in avi since multi references (b-frame pyramids, open gops and similar are not really that well-supported by usual .avi handling routines).users currently on my ignore list: deadrats, Stears555, marcorocchini -
Hi Selur, thanks for your answer.
My purpose is only for archive and keeping the file as lossless and close to the source.
I've capture PAL vhs tapes with Vdub as .avi with Utvideo422 commpression. But for some reason the video is captured as proggressive and not going smooth like I see the VHS tape on TV when the VCR is connected to it.
If I de-interlace it using QTGMC it looks just like on TV and smooth to watch on VLC.
So choosing UTvideo as the processor in hybrid keeps the file the original file the same because it was utvideo in the same place?
Selur Hybrid: how to export profile and/or AVS script
By Darryl In Canada in forum RestorationReplies: 1Last Post: 7th Feb 2022, 12:11 -
avi files crashes or stalls in Hybrid
By Rahneshin in forum Video ConversionReplies: 12Last Post: 21st May 2021, 09:30 -
Editor Export
By chris319 in forum EditingReplies: 6Last Post: 28th May 2020, 22:45 -
[Vegas Movie Studio] Export list of files, or read .VF file with other app?
By yetanotherlogin in forum EditingReplies: 9Last Post: 1st Oct 2019, 19:09 -
Crashing during export?
By Anothuor in forum ComputerReplies: 7Last Post: 7th Sep 2019, 11:45
