Hi – Im looking for some tech help / explanation, or even suggestion of a more suitable group to post this problem!
I am doing some sports filming where my video feed goes to others at the venue. Their software often uses an ingest card such as a Blackmagic mini recorder, or a AJA UTAP HDMI.
My camera only outputs SDI video (Sony PMW-EX1) which is 1080 50i. Their software requires 1080 25P.
So I have purchased a scaler / converter that takes my SDI and converts it to HDMI 25p. This is verified by either my monitor which confirms the signal is 25p, and ingest software such as blackmagic Media Express, which confirms input with picture.
YET the software that they use does not see the video signal when set to 25p, but if I take an HDMI at 25p direct from a different camera / pro-sumer camera, the software sees it immediately!!!
So my question is, is it possible that there is a difference between the sdi converted 25p signal, and the non pro camera (which works)? And therefore what can I look to change on the sdi camera to possibly help?
Thanks in advance
Peter
Results 1 to 1 of 1
How to know if a 1080 video is being played in 1080 or 720?
By Kryzon in forum Newbie / General discussionsReplies: 9Last Post: 18th Sep 2023, 07:58 -
Converting 1080/25i to 1080/50i
By simon744 in forum Video ConversionReplies: 41Last Post: 14th Sep 2023, 17:55 -
Convert 1080/60p to 1080/30p ???
By NewTwoVideo in forum Video ConversionReplies: 19Last Post: 24th Nov 2021, 16:55 -
Simple FFmpeg HEVC 1080i (DVBS2 HD) to 1080 25p, problems with interlacing
By Mr Whippy in forum Video ConversionReplies: 2Last Post: 27th Feb 2021, 05:07 -
Disadvantages - 25p to 24p
By dira in forum Video ConversionReplies: 2Last Post: 23rd Feb 2020, 09:41
