  1. Hi... I have this problem, I wanto to apply a Cube Lut with Staxrip.
    This is my script:
    tcFile = "%temp_file%_timestamps.txt" # timestamps file path
    Exist(tcFile) ? FFVideoSource("%source_file%", cachefile="%source_temp_file%.ffindex", timecodes=tcFile) : FFVideoSource("%source_file%", cachefile="%source_temp_file%.ffindex")
    ConvertBits(10)
    ColorYUV(gamma_y=-25, opt="coring")
    SetFilterMTMode("DEFAULT_MT_MODE", 2)
    CASm(1.0)
    Prefetch(16)
    Cube("A:\PORTABLE\StaxRip\LUTS\06_Vlog LUTs_For Skin Tone.cube")
    Neo_f3kdb(dynamic_grain=true)
    But this error appear:
    Script Error
    AVSCube: input must be CS_RGBP16
    (C:\Users\Administrator\Desktop\Jan Akkerman\2005 Pietons + Just Because_temp\2005 Pietons + Just Because_new.avs, line 51)
    1) What I have to do?
    2) It's better to apply a LUT before or after upscaling?
  2. Without knowing the format your source file is in, see: http://avisynth.nl/index.php/AVSCube it shows how to convert to YUV420 to 16bit Full Range Planar RGB.
    btw. iirc. 'Prefetch' should be applied after all the filters,...
    users currently on my ignore list: deadrats, Stears555
